Home > Puma (Tdci) > How many thermostats
Page 2 of 2 <12
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Btw the thermostat is not a three way valve, it doesnt stop the flow from circulating, it only introduces the cooler side in a mix where some of the hot coolant is recirculated and the hot side into the radiator pushes the cooler coolant through the thermostat.
That is why it fails more often than not. Can't leave well enough alone
Post #865376 4th Nov 2020 3:05pm
Smoeandco
Australia
Re: How many thermostats
dgardel wrote:
Kevlar wrote:
Oil Cooler thermostat LR004557LR (This one I located on the oil cooler but mine had been removed, should it have a thermostat on the cooler ?)
https://www.island-4x4.co.uk/engine-cooler...-7591.html
Installed only on the very early Pumas, from 2008 it was no longer installed by LR . Absolutely redundant (it is the temperature of the water that drives) and induced too many oil pressure drops. Indeed, if installed it is better to remove it.
@dgardel - I have a coolant leak from the elbow at the oil cooler joint. Would you suggest removing the thermostat and just running the coolant pipe direct to the cooler?
Post #1007162 10th Sep 2023 10:52pm
dgardel
Italy
IMHO, YES! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #1007261 11th Sep 2023 6:01pm
unclesam
Poland 2008 Defender 110 Puma 2.4 SW Cobar Blue
How it can cause oil pressure drop if its installed on water pipe ? just by cooling down the oil should rather raise pressure than drop.
Post #1041227 29th Jul 2024 5:50am
Page 2 of 2 <12
