Home > Td5 > Injector cleaners/ fuel additives
Page 1 of 3 123>
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just curious, I used to regularly add Stanadyne diesel additive to my 300Tdi and it ran quieter with it. Does anyone use anything in your Td5? If so, what do you use? I have added nothing to my diesel for nine years of Td5 ownership (regular maintenance and service excluded๐Ÿ˜‰).
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1007040 9th Sep 2023 9:19pm
Kev the Rev
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
I acquired a TDCI earlier this year with 100k and a patchy service history
I bought a bottle of Forte injector cleaner from LR Parts and I'm sure it runs a lot better now but I'm not sure if it's just imagined.
I thought it was worth trying it
There's a video on Youtube if you want to take a look
Post #1007054 9th Sep 2023 11:11pm
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
I put 300ml of 2 Stroke oil per tank full in mine (should be 375ml but my little bottle is only 300...๐Ÿ˜).
She runs quieter and it definitely improves our fuel consumption ๐Ÿ‘๐Ÿ‘๐Ÿ‘ 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1007088 10th Sep 2023 10:03am
Dinnu
I just started using the Millers Diesel Power Eco Max. Time will tell if it does good or not. On a 2.2 btw. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1007090 10th Sep 2023 10:07am
andylee
I had and issue with rough running (rattle and smoke) and a fuel pump fail which I put down to using cheaper supermarket diesel. Since fitting a new fuel pump Ive been adding Millers Oils Diesel Power Ecomax Fuel Treatment regularly and the engine has been running better then ever. Td5 15P.
Post #1007119 10th Sep 2023 5:33pm
andylee
Post #1007120 10th Sep 2023 5:34pm
Ianh
Once every year, circa 5k miles I use forte diesel injector cleaner. Then Millers diesel ecomax treatment every time I fill with diesel.
The engine does feel like it appreciates it, which may be a placebo effect, but given the costs of the above is a drop in the ocean compared to yearly fuel costs Iโ€™m happy to do it.
Post #1007122 10th Sep 2023 5:51pm
adseybear
Canada
Notice you're in Canada also,
Since having my Td5 over, and we also have a BMW 328d, I put a dose of Hot Shots Secret Everyday Diesel Treatment in with every fuel fill up for both. Has very good ratings in Canada and USA.
In the UK I used Millers additive, but they don't seem to export. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #1007137 10th Sep 2023 7:37pm
My 2.4 TDCi had become even more rattly than usual recently (at just under 270k miles) and in particular had developed a heavy rattle at 2000 rpm under certain combinations of throttle and boost, a rattle which was similar to the phenomenon known as "pinking" on older petrol engines. I was gearing up to an injector change, on the theory that they've never been out and each one has injected around 2500 gallons of diesel, but I thought I'd try a shot of Forte injector cleaner first, nothing ventured nothing gained and all that.
So on Saturday before filling the tank I emptied a bottle of Forte into it. Some 200 miles.later and I can honestly say that I wouldn't have believed it if someone had told me what a difference it would make! The pinking rattle has gone, the normal injector noise is massively reduced, and the vehicle feels smoother and more free running. I am frankly stunned at how effective it seems to have been, and am definitely a convert.
If I'd tried it before buying a set of brand new injectors I could have saved nearly a grand!
Post #1008837 25th Sep 2023 6:02pm
Ianh
Good to hear itโ€™s worked for you Blackwolf, Iโ€™ve used it on petrol engines with high miles and they ran much smoother and sailed through MOT emissions tests. Hence I use once a year in my 2.2 now.
Post #1008849 25th Sep 2023 7:11pm
geobloke
Re: Injector cleaners/ fuel additives
Yes, I do feed Miffy (TD5) additives from time to time. A few reasons, the ultra low sulphur diesel is supposed to be quite drying and the other reason is to reduce the opportunity of growth within the tank. That fuel pump pre-filter can foul up.
I have used 2-stroke oil, Millers and whatever is on offer at the time. Any difference?! Meh... hard to tell and hard to prove anything really. The only things I will say is that the pump pre-filter was disgusting before I began treating the fuel and on last inspection it was beautifully clean and clear of growth. All I can think is that the pump will thank me. And the fuel economy is still as good as it ever was.
Now... In Phoebe (Freelander 2 TD4) with her variable geometry turbo the additives do make a huge difference and keep that lovely turbo working as it should.
Post #1008855 25th Sep 2023 8:06pm
jst
How long have you been doing that for? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1008860 25th Sep 2023 8:51pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Iโ€™m another Miller Ecomax user, I use it in both my diesels and it immediately makes them run quieter and smoother.
Thumbs Up Ride like you stole it!!
If Iโ€™m not on a bike itโ€™s because only a 4x4 will doโ€ฆ
2011 2.4 Puma 90 HT
Post #1008900 26th Sep 2023 5:47am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Interesting.
Do you use the additives on Premium Diesel (like BP Ultimate, Shell V-Power, Total Excellium, etc.) or on Standard Diesel ?
I am tempted to think that additives on Standard Diesel is more or less the same as Premium Diesel alone.
I stick to Premium Diesel for my Puma 2.4. And think that adding more additives would be too much. But happy to listen to what others have to say.
/Mat
Post #1008919 26th Sep 2023 10:20am
geobloke
Hi Mat. I only use additives on standard diesel and that is because that is all that is available around me.
You do the best with what you have access to, right?!
Post #1008920 26th Sep 2023 10:34am
Page 1 of 3 123>
