Home > For Sale & Wanted > [For Sale] Parts clearout [updated]
rallysteve
In the interests of getting rid of my surplus of leftover parts before we move house I have dug out the following (photos to follow):
Two rear wheel arches - shabby bare black plasric with quite a few broken mountings £5pr [BINNED]
YRM galvanised under floor support (part no. 061B) - new/unused £30
YRM 110/130 TD5 fuel tank strap (part no. 138B) - was on the vehicle for about 5years but totally usable £15
YRM stainless sill brackets (part no. 070) - brand new set of 6 [SOLD]
YRM stainless rear side panel to capping double ended bolt things (part no. 1107A) - new but missing washers £4
YRM 110 rear quarter/wing stay/mudflap reinforcement piece (part no. 310) only one of these with its required stainless bolts. No adhesive included £7.
YRM wheel arch stiffeners (part no. 337) - unused but painted in red Jotun 2-pack epoxy primer £22
YRM front stainless spring retainers (part no. 220) - test fitted (unsuccesfully) but otherwise new £15
Gwyn Lewis front spring retainers (hook type, part no. GL1054). These are galvanised then painted in Jotun 2-Pack epoxy primer and battleship grey Jotun 2-pack topcoat - [SOLD]
110 TD5/tdci stainless midpipe replacement pipe - used with some corrosion but still got plenty of life left £10
110 TD5/tdci rear exhaust section - Good condition genuine LR £35
Pair of rear stub axles for disc brakes Salisbury Axle (FTC1740G) - new in boxes, OEM EAC branded £50pr [SOLD]
Pair of Delphi OEM rear disc brakes (LR017953G) - brand new in box, bought in error £20 [PROVISIONALLY SOLD]
Pair of genuine 110 CSW rear sliding windows - factory green tint glass. Good condition with some minor scratches on the internal faces of the frames - £50
2 tab heated windscreen, no idea on the age of it but looks in good order, green tint £20 [PROVISIONALLY SOLD]
Genuine LR 2nd row LH door card (ELB502210PUY) - black for later pressed steel doors, good as new in box - £90 [SOLD]
Set of 110 stainless rear brake pad shims - used but good condition £5
Pair of 02 TD5 onwards wiper wheelboxes/spindles. Genuine LR parts which I had fitted to my vehicle for about 4 years. Some surface rust but move freely £10
Set of all three Td5 PAS pipes - these are the old ones from my vehicle. There were no noticable leaks when i removed them but they are obviously used/old £30/set
Pair of vent flaps - terrible paint but reasonably straight. With stainless vent pins £10
Pair of genuine bonnet hinges - sand blasted £10
Pair of dropdown tailgate hinges (bits which bolt to the tailgate not crossmember) - part sandblasted £10
Set of four captive nut plates for door latch strikers - £5
TD5/TDCI locking fuel cap with 2 keys - £5
Pre Td5 locking fuel cap and keys, still sealed in packet - £5
Pair of fized second row seat brackets from my Td5 Doublecab - £5 [BINNED]
Pair of seatbox lid rear retainer angle pieces - £5
Full set of LOF brake caliper seals. Enough to do 12 pistons. These were for my 110 Td5 but should fit all but very early front calipers and maybe other rears which share the same size pistons as the front. - £10
Pair of OEM seals for between caliper halves {part no - 17H8764L] - £5
Pair of used Td5 engine mounts from my 02 - £5 [BINNED]
Pair of R380 floor panels - £5 [BINNED]
Original track rod guard (small thing that bolts on the diff nose - £5
Set of steel wheel nuts - £5
Par of fixed Securon 3point seatbelts - £5 [SOLD]
Pair of britpart headlamp bowls - new in packet -£5
Pair of black headlamp rings - new - £5 [SOLD]
Bonnet Alarm Switch Bracket - £5
Heater box to dash seal bracket - £5
Pair of genuine bonnet hinges - bare shotblasted -£5
PAS bottle - £5
Original front screenwash pump from my Td5 - £2
All parts currently located in the Hope Valley (SK17) but can also bring them back home to near M1 J31 or upto West Cumbria/Whitehaven area.
I am happy to post the smaller items at buyers cost although i wont be very quick at this as i am working away most of the time currently.
Steve
Post #1004678 18th Aug 2023 8:48pm
Jim1988
Do you have pictures of the sliding windows? Do they rattle and would you know if they would fit in place of 90 td5 genuine windows?
Post #1004683 18th Aug 2023 10:28pm
NickMc
I would take the rear discs if you’d post? I’d love the heated screen, but don’t know how I’d get it, I have a lorry coming from Skelsmersdale direction and out of liverpool next week, but I don’t think that’s anywhere near?
Post #1004692 18th Aug 2023 11:15pm
donmacn
Hi Steve,
I’d take the Gwyn L. spring retainers, and the YRM sill brackets please! Chosen small stuff for postage given where I am!
PM inbound. Ta.
Donald Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1004708 19th Aug 2023 8:12am
rallysteve
Will grab some photos of them ASAP for you. They are the same on a 90 and 110 as far as I am aware so should fit your 90. Cant be sure on the rattle as i have never had them fitted. They were only removed to fit dark tint versions though, not due to being worn out.
Post #1004710 19th Aug 2023 8:37am
rallysteve
Happy to price up postage for the discs if you PM me an address. Afraid i dont have anything suitable to parcel the screen up with though.
Post #1004711 19th Aug 2023 8:39am
rallysteve
donmacn wrote:
Hi Steve,
PM inbound. Ta.
Donald
No problems, will get those out whilst i am at the workshop today Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #1004712 19th Aug 2023 8:39am
Jim1988
Thanks mate, please send some photos when you get chance then. PM me if easier, I could collect next weekend 👌
Post #1004713 19th Aug 2023 8:41am
NickMc
Sent you a PM Steve, I might have a solution Thumbs Up
Post #1004737 19th Aug 2023 1:10pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I'd be interested in the windscreen and PAS pipes - happy to collect from woodall area. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1005104 22nd Aug 2023 10:57am
rallysteve
Hi,
Windscreen provisionally spoken for, but PAS pipes still available. I can meet you at Woodall services or similar one evening this weekend if you like on my way back from the workshop?
Cheers,
Post #1005111 22nd Aug 2023 11:16am
Hazza
No problem at all.
I can't do this weekend unfortunately, but perhaps best to wait and see whether the windscreen becomes available or not and I can make sure it's just one trip? (I'm coming from the other side of Leeds so a bit of a drive). Cheers 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1005113 22nd Aug 2023 11:18am
rallysteve
Updated list with pics 02' 110 TD5 Double Cab Rebuild Thread
Post #1006844 7th Sep 2023 10:03pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Pm on way
Post #1006885 8th Sep 2023 9:25am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Could I take;
And the original track rod guard.
All would need posting if that's OK.
Many thanks.
Mick
Post #1006968 9th Sep 2023 6:39am
