![]() | Home > Maintenance & Modifications > R380 gearbox oil cooler adapter - |
I only have a small cooler but it is enough to reduce the oil temp by 10 degrees or so on a long hot run. A front mounted cooler would work better for certain, but here in Wales the side mounted (underneath the passenger footwell) cooler works just fine. I fitted the thermostatic version of the gearbox adapter so only effects the oil temp when up to temperature.
The real difference is seen when you do an oil change, it used to come out dark and smelling burnt, but now it comes out clearer and doesn't. Surely must be a good thing ![]() Now I no longer have AC I do have the space for a front mounted cooler, so if Miffy is required to spend time in hotter climes I will extend to the front like LR did. |
Hi Steve. This is the route I took (see page one of this thread) and like you I was thrilled when the wax plunge worked as it should do. IMHO the this thermostatic adapter is the way to go if you live in the UK given our annual temperature range.
As for the M20x1.5 thread, yes this is what the adapter uses. I used a set of AN fittings and IIRC I had to trim down the depth of the AN fitting a little so it tightened up nicely. I also used son thread sealer and a downy washer to make sure there were no leaks. All is still working perfectly after 3 years of use. The pipework does not need to be metal, but it does need to be oil compatible. I used the braided rubber hose commonly used with AN fittings as I like the abrasion resistance of it. |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
That’s awesome thank you…. Will get cracking on with this now … I agree the thermo ones are the way forward as old at wrong temp can cause wear to hot or cold.
Thank you for your help 👍👍👍 ![]() Click image to enlarge @steve_overland on Insta. 110 expedition vehicle with pop roof |
Welcome Steve. Love a white Defender
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
If anyone after an adaptor, I have one from an R380 D1, £75 inc postage to UK mainland
Just seen this if any of you are interested https://www.ebay.co.uk/itm/266045555310?ha...ondition=4
Could I ask where you got your finned cooler from as want to fit similar but can only find one with 1/4 not fittings on it... or do you think they would work... @steve_overland on Insta. 110 expedition vehicle with pop roof |
think have found it..... is this the one you used.... they also do a dual pass with 1/4 npt.. do you think this would also work or are the fittings too small?
https://www.speedingparts.co.uk/p/fuelsyst...html?_gl=1*93dtu7*_up*MQ..&gclid=Cj0KCQjwla-hBhD7ARIsAM9tQKvAbI7Tnitn5ivWY3fr5YdezHqXuzPCgzNPT2pxx7lrH5EiZbET_Z4aAjPWEALw_wcB @steve_overland on Insta. 110 expedition vehicle with pop roof |
hi all in reference my last post ... does anyone see any problems with the 1/4 not dual pass?? @steve_overland on Insta.
