Home > Puma (Tdci) > Exhaust Knocking on Chassis?
the_lincs_landies
Hi All
When I am driving along I get a metallic knocking noise when going over bumps - almost like something metallic is bouncing and then making contact with something else. I say bouncing as it seems to be a few knocks with lower severity each time. (I’ll try and record at some point)
Whilst investigating i for under the car and noticed there is enough play in the rear exhaust hanger for the silence for make contact with the chassis. Could this be the cause of my knocking, and is that normal to have that much movement? The hangers don’t seem particularly worn, but I genuinely can’t dine anything else that could be making this knocking noise…
Post #1005839 29th Aug 2023 9:12pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
It could be. I had a similar problem recently, the exhaust was catching the gearbox cross member. It turned out to be the gearbox mounting had sagged and partly broken, this then broke the exhaust rubber and caused a knock from the exhaust over bumps and a vibration when accelerating. If one of the rubbers has gone you should be able to see some marking on the chassis or axle where it's catching and also make a similar noise by wobbling the exhaust.
Post #1005841 29th Aug 2023 9:33pm
HardCharger
Check your suspension and shock bushings. Don't forget the the A-Arm ball joint while you're at it.
Post #1005855 30th Aug 2023 3:18am
Daysleepers
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Keswick Green
I haven’t had this with a defender but have seen similar things when engine mounts have gone. Often the RMM.
Post #1005876 30th Aug 2023 8:54am
devnull
Mid exhaust hanger collides with the rear propshaft on the bumps.
Post #1005897 30th Aug 2023 10:42am
the_lincs_landies
Thanks all, these give me some things to check over at the weekend.
I am hoping it is what devnull has suggested, and I am hoping that I van fix it with a new rubber hanger.
I fear, though, that it could be what HardCharger has suggested, as the advisories from the last MOT do state the rear shocks have "slightly worn" bushes.
It quite a hard knock mind you, its like a loud metallic clank followed by a series of "fading" glangs (assuming whilst the unintended motion slows to a stop)
Post #1005900 30th Aug 2023 11:42am
NickMc
Check the hanger mount on the crossmember isn’t on back to front.
Post #1005931 30th Aug 2023 4:02pm
the_lincs_landies
Thanks NickMc, I’ll add that to the list. Is there a man easy way to tell which way around it should go?
Post #1005969 30th Aug 2023 9:09pm
the_lincs_landies
So, it turns out I may have fixed this without knowing what it was whilst the car was sat on the drive fora substantial period of time.
The drop plate of this little blighter, being secured by heavy duty bars and split pins, had an amount of play in it when secured. Enough to make it jump about and knock when going over bumps etc. and then the lesser bangs being the subsequent motion where it settled back down to where it rests.
Oh well, that's a knock off of the list, even if most of the stuff suggested does need attention at some point... Embarassed
Post #1006564 5th Sep 2023 3:24pm
