Home > In Car Electronics > Defender TD5 Cruise Control Install
bankz5152
Cruise control in! Courtesy of Empire Tuning, excellent well thought out kit!. Very much plug and play, much better than my attempt on the old 110 Laughing
Empires kit also gives an option for a tacho! Which is a great feature.
Whole thing took about 45mins to install inc modifying the cowl (they do provide a pre modified one though!)
Great upgrade, easy to install. Best bet is find your own D2 switch though, getting hard to find now.
Makes the long drives much easier Very Happy Instagram @defender_ventures
Empire Tuning - Agent
Post #1005804 29th Aug 2023 6:58pm
geobloke
This is uselesss without photos mate... Useless...! Rolling Eyes
Post #1005806 29th Aug 2023 7:01pm
bankz5152
Better?
Post #1005815 29th Aug 2023 7:30pm
geobloke
Ahhhh that kit. Yes that is better. I kind of wish I had gone that route rather than DIY'ing it for myself. Very neat with the Disco switches.
Curious about the tacho wiring too, that is a neat extra to have in the loom.
Post #1005817 29th Aug 2023 7:39pm
Jabberwocky
Luxembourg
I wanted to do the same however I have a 10p engine with an nnn ECU which according to empire is a long way off in their plans🤷‍♂️
Post #1005949 30th Aug 2023 6:33pm
Martin
Site Admin
If it's an NNN ecu it's got cruise.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1005962 30th Aug 2023 8:26pm
bankz5152
Yeah it should work! Instagram @defender_ventures
Post #1005964 30th Aug 2023 8:33pm
Jabberwocky
Luxembourg
I asked empire if it would work and they said no.
Post #1005972 31st Aug 2023 12:38am
geobloke
That is what I thought too. As long as you have an NNN ECU Rolling Eyes News to me.
Post #1005984 31st Aug 2023 7:45am
AJC
I have cc on mine, self installed. all need to remember if they have change transfer box to a different ratio you will need a speedo healer for it to work
Post #1006047 31st Aug 2023 5:04pm
bankz5152
Or ratios can be changed within the ecu software. No need for a healer. Instagram @defender_ventures
Post #1006062 31st Aug 2023 6:04pm
AJC
i didn't know that, as mine was a DIY kit made up from a thread i found, i had to use a speedo healer
Post #1006147 1st Sep 2023 9:54am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I fitted Cruise Control about 10 years ago and 'upgraded' to the disco steering wheel switch about 2 years ago and it does look like it was meant to be there which I like.
I have a Roamerdrive so run the speed signal to the ECU through a 5pin relay so when the overdrive is engaged the speed signal is corrected by the Speedo healer, works a treat!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1006158 1st Sep 2023 12:03pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Is this the correct speed healer. Do I just connect all the wires and program it. I have the 1.2 transfer box and 265 tyres fitted thanks
Post #1008448 22nd Sep 2023 9:56am
geobloke
Do you have a problem with engaging the cruise control then? Curious as I never did with the 1:1.2 transfer box in Miffy. I even have a speedo healer in the spares box that I took out because it wasn't needed in the end. Weird eh?!
But yes that looks like the right speedo healer. It connects in-between the speedo sensor and loom. I managed to route it through from the ECU compartment to the speedo gear through a grommet. Speedo healer was double sided next to the ECU.
Post #1008458 22nd Sep 2023 11:40am
