Home > Maintenance & Modifications > B Pillar Trim Piece - Puma 110 Hardtop |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
+1 would like the same for my truck TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
16th Jun 2023 6:00am |
kevin-h Member Since: 24 Mar 2020 Location: Huddersfield Posts: 27 |
+1 from me. I'm interested in any interior panels for a 110 Hard Top, they seem available for other versions but not the Hard Top.
16th Jun 2023 11:20am |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 |
So am I really, being lazy with my camper build - Plastic trim covered in carpet would be so much easier, as you can work on it out of the car. Whats really weird, is it looks like you can get a panel for a 90 hardtop from MUD, but the 110 version is only for Utility |
16th Jun 2023 12:06pm |
+1
16th Jun 2023 12:23pm |
Morning All,
As an update for those interested in the same as myself, I have taken a punt on these and will feed back. I was browsing google and came across these (really) expensive carbon ones. The interesting part was this: Click image to enlarge So, Instead of blowing £240 on a couple of trim pieces, I have bought a pair of original LR ones from ebay for £35 and will feed back how I get on. Fingers crossed! |
29th Aug 2023 8:10am |
Looking forward to seenig how it looks!
Your message prompted me to do a quick google search and I just found this https://www.lasalle-trim.co.uk/product/defender-b-pillar-trim/ Looks like a couple of options including paintable @ £65 each TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
29th Aug 2023 8:56am |
I think I saw those before, but wasn't 100% because they specifically say "County Station Wagon". The carbon ones stated that they were for all models and had the same shape as the ebay specials.
If anyone tries the lasalle with success I may consider in the future - for now I need the cheapest options possible |
29th Aug 2023 9:14am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1630 |
Are you talking about the little plastic filler that screws on the edge of the hardtop panel before the window Trim on a 90/110?
29th Aug 2023 3:26pm |
This is the trim panel that sits behind the high level seatbelt mounting point, so next to the seats and find from the headlining to the seatbox
29th Aug 2023 9:07pm |
Update: I have removed the piece of 3mm white coated MDF board that the previous owner had glued on the panel behind the upper level seatbelt mount in place of a trim piece. Upon its removal it seems I may have wasted £35, What I failed to consider was that the county goes from floor to headlining, the Hardtop has the side capping (which protrudes out to meet the bulkhead) in the way.
I also don't see a hole that the upper fastener would push into in the support brace, nor anywhere for the lower. I am going to see when they arrive if I can fabricate a way for them to secure, and see if they can be modified to accommodate the cappings. Surprised there isn't something specific to the hardtop on the market already tbh... |
30th Aug 2023 1:17pm |
Ok, so here is the moment you have all been waiting for...today they arrived.
Well, it was a total flop. My previous update where I made my assumption that they would foul on the bulkhead/capping was totally wrong. The trim piece is only goes down to the the side cappings, and well, its a little bit too skinny, and the fixing point/hole for the fir tree clips don't exist. Click image to enlarge Back to the drawing board... Is there a full length side panel trim for the 110 which would also cover this, maybe? |
31st Aug 2023 4:34pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1089 |
Click image to enlarge Looks like piece fitted on my DCPU (4 door) which is normally the same arrangement as the station wagons |
31st Aug 2023 5:29pm |
Yeah, I’m trying to find a piece to fit my 3 door hardtop but it’s proving (very) difficult!
31st Aug 2023 5:53pm |
There is a plastic piece on 90’s which is what I thought you wanted, they’re NLA though, no one makes a trim for a 110 hardtop that I know of. They mostly got trimmed out in plywood as vans I guess. This is said piece it’s only a reveal trim though, but might look good with sides made to finish it off. https://www.ebay.co.uk/itm/385320019634?mk...media=COPY |
31st Aug 2023 5:56pm |
