Home > General & Technical (L663) > Confused? heated seats X-Dynamic S (P400E) 2024
macduff
When i specced my P400E heated seats were (& still are) listed as part of the included factory base specifications. It was delivered mid week & i’ve been working though iGuide to familiarise myself & missus with what/where all the features are. I have sofar drawn a blank at working out how to enable heated seats and cant even find a mention of them in the IGuide either? This is with generic Defender 2024 iguide or one specifically for the vin in case theres a difference. Ps its a uk spec car. is this something thats fallen off the build specs for this year & if so whats the usual sequence for turning on heated seats if they are fitted ? 2023 110 P400e
Post #1005578 27th Aug 2023 4:21pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
If you have heated seats the switch is the temp control, you push this in and turn, You can also access the settings through Pivi, if I remember rightly.
This is the button to press
and you would twist it to switch it on, there are 3 levels, here on mine it is actually the cooling seats which are switched on Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1005583 27th Aug 2023 4:48pm
Hairy Dan
Just had a look in the Iguide and it is covered under climate and comfort
At least it is in the My2022 version Cheers Ian
Kielder 4x4 Safari
Post #1005585 27th Aug 2023 4:53pm
macduff
Ta all i was searching iguide for Seat , heated Seat or Heated the latter only finds heated wheel. Searching for seat te finds it Smile 2023 110 P400e
Post #1005586 27th Aug 2023 5:01pm
macduff
Just to update I didn’t appear to have the seat icon on the climate knobs & pushing them didn’t show anything regarding seat heating. Found I needed to use the seat App on Pivi where both seats were shown as off, I couldn’t turn these on whilst it was plugged in /charging but turned on ok with it running, I left these on but with no heating & this then put the seat icon on the climate knobs. 2023 110 P400e
Post #1005692 29th Aug 2023 6:55am
Hairy Dan
I'm glad you've got it sorted Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1005693 29th Aug 2023 7:11am
WizzardPrang
You can also use voice control to turn the heating on. Something like "Hey Land Rover, turn heated seats on". Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1005824 29th Aug 2023 8:14pm
