![]() | Home > Wheels & Tyres (L663) > Expected Lifespan Goodyear Adventurer A/T |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2710 ![]() ![]() |
They work fine in winter. Obviously not a proper snow tyre but no issues with road holding in rain or cold temperatures etc.
I only managed 35k out of mine, which was disappointing. They would probably have gone a bit further if I’d swapped them front/rear to even out the wear, but I changed them for proper off road tyres after puncturing the second one on a flat track. They’ve got uselessly thin sidewalls and treads for off road use. |
snowtiger Member Since: 06 Oct 2022 Location: Bavaria Posts: 32 ![]() ![]() |
Regarding the life span, does it make sense to rotate with the spare wheel, i.e. change every 5k the spare with another tire?
tonyp Member Since: 03 Feb 2023 Location: Northern Ireland Posts: 83 ![]() ![]() |
Thanks Retroanaconda
Good idea on swapping front / rear |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
![]() Click image to enlarge It’s about 5000miles and 2 days of Iceland. The side wall of the Adventurer is just not strong enough imho. I wish LR put Duratracks on the Defender. Way better tyre. |
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 ![]() ![]() |
47,000 miles so far and still plenty of tread left. Mainly road use. 5 tyre rotation pattern every 5000 miles. L663 D300 SE MY22.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
The Duratracs on my 110 weren’t much better for sidewall slashes unfortunately. I’ve had one slashed at 3000 miles and another that I thought was slashed but in fact the bead had a twig lodged in it. I’m running my new 90 on Adventures this time as part of the offroad pack ![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 163 ![]() ![]() |
The LR approved Adventurer A/Ts don't have Kevlar reinforced sidewalls and as far as I know, neither do the LR Duratracs.
Having said that, I've the Adventurer A/Ts and they are fine in the wet/snow. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
I drove the Duratracs on a 1500 truck and they were reinforced. Very good tyre. Didn’t know the LR Duras are not reinforced. Is it because of the size or for comfort reasons?
Either way, I’m driving the Yoko Geolandar G015 now for 6000km road and 1500km gravel road and quite sharp lava roads and I don’t know if the sidewall is reinforced but in similar situations the Yoko hasn’t burst so far. The Icelandic tyre guy said that he absolutely dislike the LR Goodyear. And there are a lot of new Defenders and Discos driving around here. L663 is a very popular car here. |
I believe that there are two versions of the Duratrac and Adventure available - those with the LR oval moulded in the sidewall and those without. Those without have the Kevlar reinforcement but are very difficult to obtain in the UK. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
