Home > Maintenance & Modifications > Central locking, Alarm and Dome light fail |
Landstryker Member Since: 23 Aug 2023 Location: Tonsberg Posts: 3 |
Click image to enlarge UPDATE Feel like an idiot.. I located the “correct” fuse panel and a blown 20a fuse that did the trick. Guessing a underlying issue is with either a frayed wire or sticking latch that draws high Amps so I will continue with the project of determining the cause if the fuse blows again. Thank you to those who considered replying, and here is a image of the culprit fuse location if anyone else face a similar issue Location is below right side front seat |
23rd Aug 2023 8:40am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2081 |
Check the wire loom that goes to your doors, especially rear doors if you have a 110, wires fracture or break and can short circuit. It’s a known problem on RHD defenders.
See this topic and the additional links to topics in it https://www.defender2.net/forum/topic80757.html?highlight=park |
23rd Aug 2023 9:57pm |
Much obliged and with thanks Ianh 🙏 👍
24th Aug 2023 4:39am |
