![]() | Home > Maintenance & Modifications > 1997 County 300TDI engine issues - help please |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1231 ![]() ![]() ![]() |
I appreciate you are desperate to get this sorted.
I imagine you have invested heavily in the repairs already completed.. therefore I would be back at the garage insisting they help you Surely they would want you to drive away happy with their work. I’d pop back and politely explain that it’s not acceptable Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Have you looked in the tank? I have seen it when a new tank was fitted and there was a label inside the tank that wasn't removed. This would get sucked onto the fuel line blocking it and then when stopped if would fall back down. Got to be worth a look, if you take the sender out the top you should be able to see. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
NickA Member Since: 22 Aug 2023 Location: Aberdeen, Scotland Posts: 3 ![]() ![]() ![]() |
Thanks Clemmo, to be fair the garage is miffed withe problem and havent charged me for much of the work done. |
thanks Dave, its the original tank, they drained it and cleared all of the gunk out and also found silicone, they then put a new fuel filter in but still not fixed. |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 806 ![]() ![]() |
The Tdi fuel system is fairly simple.
To me it sounds like an air leak still. With the bonnet open, have the vehicle running, rev it up a few times and shut the engine off, then stick your ear in the engine bay by the filter and pump and listen for any hissing. A new lift pump is cheap and easy to swap, so worth trying. I'd also be tempted just to tweak the filter a little tighter as they can leak (suck in air) around the seal if not done properly. In theory it could be an injector pump issue, but less likely. If you are prepared to have a go yourself at doing bits it'll be a lot cheaper long run than getting a garage to do it. |
