Home > Td5 > 2005 Td5 Intermittent starting issue (suspect electrical) |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1089 |
Or the relay powering the ECU? Is there not one for that?
2nd Jul 2023 12:52pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 487 |
Thats your ECU load relay its under the drivers seat makes sure the connector block isnt corroaded and all the female spade connectors in the block are a tight fit on the relay. Swap the relay with one of the other less essential relays.
2nd Jul 2023 2:02pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
So the problem has now evolved ... it is now starting OK (fire's up immediately once glow plug lamp has extinguished, as normal) but then coughs or cuts out. I noticed that when it coughs / stutters, the yellow 'engine management' light flashes up. It has once coughed and then continued running as normal, next start-up it actually cut out and had to be restarted.
I'm guessing that the coughing / cutting out is fuel starvation? I'm also guessing that as it starts and runs it's not the ECU (as presumably if the ECU was dead, it just wouldn't run). 2005 Td5 | 90 Station Wagon | Tonga Green |
13th Jul 2023 12:32pm |
Just by way of conclusion to this - I contacted the local LR specialist where I used to live in North Yorkshire (DPG Defenders in Kirkbymoorside), who I had previously used for all servicing etc. for several years. He advised that the relays under the driver's seat were the most likely culprit, and it sounded like the main relay.
I purchase a set of 3 new relays online (thought I might as well just swap all of them for new) so that's the main relay, fuel pump relay and glow plugs relay, which seems to have solved the problem. I have run it now for a couple of weeks since swapping the relays and have had no further issues with starting / cutting out. When I took the old relays out, I prized the plastic covers off and had a look inside. Sure enough, there was significant wear / pitting to the contacts on all of them and one in particular (which I suspect was the main relay - I should have kept better track of which one was which!). Anyway, if anyone has a similar issue, replacing the relays appears to have worked for me. Dunstan at DPG said that the relays on Td5s should really be considered a service item - they usually need replacing after 10 years and will eventually cause issues. 2005 Td5 | 90 Station Wagon | Tonga Green |
18th Aug 2023 9:31am |
Excellent Sorry I did not see your original post I probably could have saved you much effort as I have documented the degraded relay issue in the Workshop adventures of Miffy thread.
Hope you have many more happy miles |
18th Aug 2023 10:20am |
@geobloke - thanks, I actually found your thread during my research and found it very useful - it confirmed what the LR Specialist was advising and also gave me some images to understand / compare against. My relays were in a very similar state! 2005 Td5 | 90 Station Wagon | Tonga Green
18th Aug 2023 10:24am |
Marvellous That is the whole point of documenting the maintenance process
18th Aug 2023 10:29am |
