Home > V8 > Stage One V8 4.6 GEMS Build
Page 2 of 2 <12
mikeh501
My alisport nas rad came with a shroud, I’d ask if it’s a mistake. Also on the pic that rad is fitted with a fan switch already. You need a couple of relays to wire it but one connector is 83 degrees and the other is 93 iirc. You wire one fan to the 83 and one to 93 so they both come on.
Post #956673 27th Jun 2022 7:02pm
cartoonhead wrote:
GREENI wrote:
Very nice!
Watching with interest.
That's handy, because I'll probably have a few questions for you Laughing
Happy to help.. there’s a few on here who have great knowledge.
Post #956691 27th Jun 2022 9:07pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
cartoonhead wrote:
Thanks for the tips MercianRover - I wasn't familiar with the x-eng fan switch, I'll definitely do that. Out of interest what temp thermostat are you running on your 100"?
Thermal switch adapter for bottom hose:
https://foundry4x4.co.uk/index.php?route=p...uct_id=133
My thermostat is whatever was standard for 3.9 EFI on 14CU.
Factory knew what they were doing.
O/T: keep the paper element airbox and filter.
Post #956717 28th Jun 2022 9:46am
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Long overdue update! Engine is in, all the plumbing is done. It’s not the prettiest setup but it’ll do the job. Next job is to sort out an exhaust and figure out what some of the wires do.
 @tab.travels on instagram
Defender 130 2.2 TDCI
Defender 90 TD5
80" CCV Trialer 4.6 V8 (14CUX)
Stage One V8 109 - 3.5 V8
Stage One V8 109 - 4.6 V8 (GEMS) - in progress
Range Rover L322 4.4 TDV8
Freelander 1 2.0 TD4
Post #968672 22nd Oct 2022 8:23pm
Nice. Cool
Post #969082 27th Oct 2022 5:26pm
cartoonhead
Long overdue update: With the help of the Rover V8 Appreciation group on FB, I think I've sorted the last few niggles with this. She's running nicely and pulls like a train. I really need some taller gearing next.
The engine bay is a bit scabby, but here she is all plumbed up:
Once I've got the taller gearing I'll work out what MPG I'm getting Shocked @tab.travels on instagram
Defender 90 TD5
Post #1004590 18th Aug 2023 10:02am
JeremyJ
Change the transfer gearing in the LT95 to Range Rover ratios, will transform it!
Post #1004679 18th Aug 2023 7:50pm
Page 2 of 2 <12
