- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Discovery 300Tdi auto FiP...converting to non electronic? |
Linds Hanson wrote:You will need non EDC pump, throttle cable, the kick down cable should go to the injection pump but you should be able to rig something from the original KD linkage.
Thanks Linds, i thought it was something along these lines. the elctronic bit it too far integrated in the mechical pump I think to be able to totally remove it.
15th Aug 2023 1:43pm |
Linds Hanson
NickMc wrote:Can you not Bypass that style of pump Linds? It’s a long time since I messed with one, but I thought you could run these like the old style one wire, it’s the full EDC pump you can’t? Yes Discovery 300tdi auto had EDC pump only RRC ran manual pump and auto.
15th Aug 2023 4:45pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
