Home > Td5 > td5 engine - r380 bolts
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
I am wrapping my engine rebuild and on tuesday or latest wednesday the engine is finally going back in. I noted that somehow we might have disposed the old mount screws for the block to the gearbox. I checked trusty lrworkshop but cant figure out the parts number for the right screws ...
is FS112406 the correct bolt (m12x40) for mounting the engine back to the gearbox?
thanks
Doruk
 Td5 110 Station
Post #997469 25th Jun 2023 1:10pm
rallysteve
From memory they are M10 flange head bolts so looks like the part number is possibly:
FB110101L
Post #997472 25th Jun 2023 2:08pm
NickMc
They’re not all the same iirc, and there’s one short M8 goes in the tin “flywheel” plate from the other side too.
Post #997497 25th Jun 2023 7:00pm
NickMc
Did you get sorted with this I removed a set today
Post #1003700 10th Aug 2023 11:10pm
