Home > Maintenance & Modifications > Front Shock Absorber Replacement |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
As other people have already mentioned, changing the front dampers on PUMA models is a bit more fraught as there are various pipes, air box etc. in the way.
When I did mine I found that getting the old turret passed the various obstructions to be a right PITA. I was installing new Gwyn Lewis HD turrets and rings so I did not need the old original ones. I used a small cut off tool https://www.machinemart.co.uk/p/clarke-cat...-off-tool/ to cut around the top of the turret. The much smaller top part of the turret and the old damper are much easier to pass through the limited space. Once the damper is out of the way, the bulky bottom part of the turret can come out sideways. |
6th Mar 2023 2:31pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
just doing some scouting before i change my front shocks shocks (puma 2015) the turret plastic access cover on the wing shield appears very difficult to remove on the puma with aircon pipes on the near side as the airbox is in the way ......do you have to remove the airbiox first?
20th May 2023 7:31pm |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 219 |
Hey Nitram
Just done this last week new shocks all round. On the drivers side the screw hidden by the airbox can be unscrewed from under the wheel arch with a pair of pliers. No need to remove the airbox. When you refit you can screw it in upside down from inside the wheel arch with a screw driver. |
21st May 2023 1:11pm |
is anybody concerned with the plastic turret cap not exactly being sealed very well and crud /dust making it into the engine bay?
just t confirm the torque settings for the shock bushes is 38 nm top and bottom ? |
31st May 2023 10:49am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
It doesnt seal. Dont worry about Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
31st May 2023 3:10pm |
Thanks jst ..changed my springs and didnt need spring compressors and you wont uless your using huge springs.
I simply used a procedure see ride confort thread bottle jack on axle to give enough room for springs to fall out. My drive is sloping so i cannot safely jack up both wheels. !.Remove turret cover 2.Jack up car on chassis axle stands for safety 3. Remove wheel 4.Jack under axle(bottle) of side your doing and support axle only. 5.Remove botton nut of shock(bracing shock with mole grips) 6.Remove turret nuts 7.lift out shock ant turret 8.lower jack on axle and remove 9.Place bottle jack on flat surface of bump stop on axle and jack up against chassis (pushing the axle down in controlled way)slowly in a controlled fashion being wary of brake hoses,springs will fall out ..no levering .pushing or shoving this should work for all except very long springs. Click image to enlarge I was surprised how controlled it was and if i can do it anybody can.Obviously there is limit to the articulation due to the brake hoses but it should work easily enough on all but the larger springs. |
10th Jun 2023 3:46pm |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 27 |
Thank you thank you thank you!!!!
Completed the job last week. Lost one of the turret ring bolts though. Small price to pay, Will just drill a hole and fit a new bolt. Definitely changing to the stainless turrets next time around. 110 SW 2.4 IZUMI BLUE |
10th Aug 2023 7:28pm |
