Home > Faults & Fixes (L663) > software 4.0.0 - Radio Sources/favourites
XplusYplusZ
I noticed a weird behavior as a result of the software upgrade in the radio stations:
BEFORE
I had 6 favourite DAB stations I could cycle backwards and forwards through using the left right arrows on the steering wheel. It would cycle alphabetically then return to the first again.
NOW
It seems to cycle through the favourites, then at the end of my favourites list is changes source from DAB to FM channels, and weirdly starts adding new favourites in the FM channels..
It's bizarre, and frustrating.
I did also update my diamond button to long-press = change media source. I don't know if that's triggered the issue, but whatever's happening, this is a bug.
Anyone have the same?
Post #1003584 10th Aug 2023 10:23am
Telemarkskier
My understanding is that you have to reset your favourites as they were not retained. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #1003757 11th Aug 2023 11:36am
XplusYplusZ
Solved it.
You need to have a profile set up and logged in, to have favorites.
When not logged in to a profile, you can set favorites, but they don't seem to stick and you encounter the weird behaviour I was experiencing - bouncing between DAB and FM when scrolling stations. It's not right and definitely a bug, but not something you need to worry about by simply setting up a profile.
Post #1004949 21st Aug 2023 9:17am
LR Nuts
I tried to upload new software V4, it failed and deleted all my favourites !!!
Shame on LR !!!!
Post #1004981 21st Aug 2023 12:58pm
XplusYplusZ
Laughing ahem - sorry to hear that... Rolling with laughter
Post #1005303 24th Aug 2023 11:50am
LR Nuts
Now got OS 4.0.0
I was looking to see when vehicle needs a service ......
365 days or 11,890mls which ever is soonest
when I bought the vehicle, a year ago, odometer read 12,988mls and I have done 9k mls in that time !!!
any one else have this problem ???
Post #1005311 24th Aug 2023 2:40pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
No! Although probably a coincidence my car popped up that it needed a service within 30 days just after I had installed 4.0.0 and has been counting the days down ever since Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1005369 24th Aug 2023 11:18pm
