  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > 2002 Headlight Issues - main beam always on with ignition
Page 2 of 3 <123>
geobloke
docperio44 wrote:
Seems original, see pic. Also found that connector on top tucked away. not sure what that is. Voltage is low at 10.6v which matches battery. there is no voltage change between switch positions 0, 1, or 2. All positions at ignition 2 have same 10.6v. so lights are on.
OK well it is the standard factory wiring at that end then. Check that off the list. The small connector is difficult to makes out. Could be a position light for a set of Halogen lights. Does the wiring for that lead back into the loom or to something like the sidelight wiring?
Post #1003477 9th Aug 2023 2:23pm
Martin
Site Admin
Can't see the wire colours because of the glare, that connector should be the horn (purple/black and black wires). Not all Defenders have 2 horns fitted Smile
Always handy to give wire colours Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003478 9th Aug 2023 2:28pm
geobloke
docperio44 wrote:
ok, I pulled the switch. some very odd wiring and taps going on back there. I have a lead see pic.
Out of the connect working back there are 3 wires: red, blue, and blue brown. All 3 are tapped with a red, blue , and black. and the 3 taps run downward. The original 3 go inward, I would assume to a relay. The 3 tapped wires run to the fuse box. Directly connected along with another yellow and another red tapped into a fuse. See pic. No idea what to do now.
My thoughts exactly Martin.
Always, always get a wary feeling when I see chocolate block connectors used... Horrid horrid things... I am wondering if the previous owner had a duff light switch and to get around buying a replacement came up with some "creative" wiring so that the main beam headlights just come on and stay on. Better that way then no lights at all.
I wouldn't be surprised if you trace and remove that wiring you can get the headlights back to factory switching.
Post #1003479 9th Aug 2023 2:30pm
docperio44
Canada 2002 Defender 110 Td5 CSW Stornoway Grey
Hmm, pulling that fuse makes lights not work at all. In any position of switch.
Post #1003483 9th Aug 2023 2:59pm
Martin
Site Admin
Stupid question, but is the light switch connected back up to this plug?
2015 D90 XS SW
Post #1003485 9th Aug 2023 3:00pm
docperio44
Not a stupid question -- the answer was NO... hahah details. Sorry
However, with both old and new switch connected. I have sidelights at 0,1,2 -- not headlights. (I have DRL/halo connected to the headlight tilt, so those are on.
Getting closer but still not headlights coming on and off with switch.
Post #1003486 9th Aug 2023 3:21pm
Martin
Site Admin
Laughing
Another check - headlights on in pos 2 require ignition on.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003487 9th Aug 2023 3:23pm
docperio44
I remebered that one! Ignition on and ingition on with start -- lights are not coming on in position 2.
Post #1003488 9th Aug 2023 3:28pm
geobloke
Now that you have removed the "interesting" wiring and are back to the factory standard. Are there fuses in place for the headlights? There are two for dipped and two for high beam.
Fuses 22 - 25 are the ones to check. https://www.lrworkshop.com/electrics/defen...nd-headers
Post #1003489 9th Aug 2023 3:37pm
docperio44
Those are in and good -- I wonder if that Tapping was done for another reason -- to bypass/redo the current headlight system. But if connected to a switch then relay -- I don't get why that rigged up system would not work with the switch.
Post #1003490 9th Aug 2023 3:51pm
Martin
Site Admin
Hmm. If it works how I have guessed, then all the wiring to the headlights through the original fuses will be OK.
A photo of any markings on the add-on relay would help me work out how this mod was supposed to work. Could you pull the relay out (leave it connected to the wires) and see if has any markings?
Also which fuse did the inline fuse tap into?
If you are getting sidelights from the switch the brown/blue 12V feed in is OK (and was the assumed supply for the relay mod).
Maybe the blue output wire from the lighting switch connector is no longer joined to the blue wire on the factory loom - perhaps taped together but no longer electrically connected?
With the relay mod in place the relay supplied the headlights through its blue wire, joined to the factory blue wire, so we know the blue wire from this joint to the rest of the car is "good". But we don't know if the original blue wire was cut, and it could be that the blue headlight output from the switch goes nowhere at the moment.
Maybe peel back a little of the tape around the blue wires and see?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003497 9th Aug 2023 4:47pm
docperio44
First, let me say thanks for the help here. Very much appreciated.
Ok, here are some pics. The fuse was inline with the number 8, car alarm fuse. there were 2 10 amps coming off that one single 10am fuse. Check the pics.
Good question about the side lights. I don’t know where those come from. I see they have different fuses. But need to check that more
Post #1003502 9th Aug 2023 5:33pm
Martin
Site Admin
Fuse 8 is an ignition source, so that makes sense.
To check.. Fuse 8 is the very top right fuse in the fuse box, on the top row? Is that where the other side of this fuse went?
The mod relay itself is a double-make relay but it with two joined 87 terminals, which now the relay is disabled but still plugged in would have caused the side light switch position to also feed the headlights Confused
Anyway, leave the relay unplugged now as plugged in it's bridging two circuits we want separate.
Need to check is under the tape on the blue wires to see what's going on.
Do you have any sort of volt meter to check inputs/output from connectors and at fuses?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003506 9th Aug 2023 5:58pm
docperio44
I messed up along the way... sorry. I told you something incorrect.
So with the mode fuse disconnected -- none of the lights work -- not even the headlight tilt (I told you they did before, Or sidelights). When I re-connect mod and fuse and light switch but leave signal/horn stalk disconected, sidelights and tilt work.
As soon as I plug in the stalk -- the main beam comes on. Does that help or hurt?
Post #1003508 9th Aug 2023 6:00pm
Martin
Site Admin
Headlight motor red/orange wire is a sidelight wire, so sidelights off = no 12V at headlight motor either.
OK, let's fill in some blanks!
Mod fuse out, light switch connected, stalk connected... do any lights work with light switch?
(Note the stalk must be fitted for the headlight supply from either the mod or the proper lighting switch to reach the headlamps. If the stalk is unplugged, headlights don't work at all. Doesn't affect sidelights).
The yellow wire for the mod, where does that go?
The black wire for the mod, where does it actually connect to? It looks like it's the brown/blue but equally I can interpret the photo another way.
We will get this sorted!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003510 9th Aug 2023 6:11pm
Page 2 of 3 <123>
