Home > Puma (Tdci) > central locking
Caterham
central locking
this could perhaps have gone under the heading general however as its a tdci I thought that where I'd post the question incase there is a difference.
as I've got a 110 xs cws with central I suspect I know the answer but I'm not sure. all doors open and close off the remote fob no problems however........
if I use the key on the drivers door when all doors are open.....what should happen ?
Post #100307 16th Nov 2011 12:24pm
Lorryman100
All the doors will lock unless this has been disabled in the 10AS.
Post #100313 16th Nov 2011 1:07pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Yep they do all lock.
When I go surfing, I always leave the electronic fob in the car and take the key off; it goes in an Aquapac under my wetsuit.
Not sure if the alarm activates or not but it's good enough for me. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #100331 16th Nov 2011 2:44pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
The movement alarm at least does not activate when you lock it with the key, I suspect it doesn't set it at all.
I've got a problem with one of the rear doors at the moment, doesn't lock or unlock automatically, will have to go to dealers for warranty fix.
Post #100333 16th Nov 2011 2:47pm
Lorryman100
As long as key mobilise and key disarm are enabled in the 10AS settings page then the key will disarm an alarm set with the fob. When locking the car with the key only, it only activates the CDL with no immediate immobilisation until the passive immobiliser kicks in after about 5 mins from the key fob being removed from the detection range of the Transducer coil. When locking with the fob, this sets the alarm as per the settings saved and initiates the immobiliser immediately.
So locking with the key only operates the CDL until the passive immobiliser kicks in.
Post #100337 16th Nov 2011 3:07pm
Caterham
thank you chaps..... Thumbs Up
that'll be another trip to the dealers then
already booked in for something else so hopefully 2 birds one stone.
Post #100338 16th Nov 2011 3:09pm
