Home > In Car Electronics > 90 R>F wire routing |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 164 |
Inside the vehicle, only at roof level in the gutter, where the interior light cables run (offside) and the rear washer pipe (nearside). There isn't really another continuous but concealed straight line through the vehicle interior from front to back, without going under carpets etc in footwells.
6th Aug 2023 5:57pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2177 |
It’s a hard top so no carpets as such but has got the LR rubber liner mat….
Don’t mind removing stuff to sort tidily ?? |
6th Aug 2023 6:26pm |
You could find an easy route up and down through the cab. If it's just one relatively small cable, like the factory tow electrics, then it could be protected with a flexible sleeve and should be pretty unobtrusive. You could enter the battery box by an existing grommet, if you have heated seats (or the blank hole if unfitted).
Personally I prefer to run these things under the vehicle in convoluted tubing. You wouldn't have to enter the cab at all, passing into the battery box by an existing grommet, hole or blanking plug (on my 2008 the battery box is full of unused factory holes). Underneath there are lots of existing looms, breather pipes, bits of chassis to cable tie your new wiring to. |
6th Aug 2023 6:34pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1645 |
What for? There is already one in the loom if I’m following you here?
6th Aug 2023 7:02pm |
Only if existing tow electrics have a 12S connection, presumably?
6th Aug 2023 7:23pm |
Yes this is effectively for a 12S connector / new 13pin connector and no they don’t exist as std…..
Was just thinking it would be far neater following an existing loom internally but maybe I just look for a very hidden ‘under’ route |
6th Aug 2023 8:32pm |
