Home > In Car Electronics > Key fob battery replacement
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I did not get the owner's manual when I got my Defender.
I think the key fob battery is getting low.
What type of battery does it take?
How do I open the fob without breaking it to replace the battery?
Post #1003195 6th Aug 2023 3:45pm
LR Nuts
You need to PM ..... RRUK ..... he does the refurb of key fobs
https://www.defender2.net/forum/topic78289.html?highlight=key
Post #1003198 6th Aug 2023 4:33pm
gcc130
What age Defender and what style of fob.
I’ve just done my 2009 two button fob, just take it off the ring and prise the two parts apart. 3v battery will have a battery number on it, can’t remember what mine was.
Swap battery, snap it back together and off you go.
Post #1003204 6th Aug 2023 5:14pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
If you have a two-button 'Lucas' style fob, part no. YWX101200 (2007-?2014) it's a CR2032 (3 volt). You open the fob by prising apart at the end where the key ring attaches. There is supposedly a procedure, set out in a post somewhere on here, but mine (2008) has never cared if I change the battery far from the vehicle without telling the alarm ECU what I am about to do... occasionally I have to realign fob and vehicle by pressing the button multiple times after the change.
Post #1003210 6th Aug 2023 5:46pm
steveww
Thanks for the help. I figured it out and swapped in a new battery, I can now zap with confidence.
Post #1003287 7th Aug 2023 3:37pm
