- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Goldstar
In the pursuit of technical information about the factory installation of load area seats into a MY 2007 onwards 110, I have stumbled across a part which is only fitted with the 7-seat option 110 but is more routinely found on the 90 (where rear seats are fitted). It is a tie-bar or seat belt reinforcing tube that is through-bolted, using a spacer, to the rear cross member and is mated to the top surface of the tubs wheel box. This then becomes the strong point for through-bolting the rear load area seat belt anchor. The part, and its associated fittings, is called a rear seat reinforcement on Microcat but does, as explained, provide the chassis tie for the seat belt.
So having thought that removing the trim would be the key difficulty, it now turns out that fitting this device followed by the subsequent hole drilling will be the next challenge. Incidently, the inertia reel bracket that I thought I would have to buy had already been factory installed.
If anybody has any photos of the interior of a 90 or 110, without carpets, that is or had been fitted with the load area seats and that shows the location of the various anchorages, I would be most grateful to see them. Equally, shots of the underside showing the top and bottom locations of the tie-bar/ tube and which show which of the captive nuts is used for the seat brackets (protruding torx screws) would be great.
Thanks.
19th Nov 2011 9:47am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
