Home > Tdi > Downpipe resting on crossmember
Page 2 of 2 <12
Oldowner
Remove the tubular crossmember and fit a td5 / Puma gearbox crossmember KVB500060 - these are a direct bolt in replacement for the earlier pre 300tdi tubular crossmember and being box section allow the clearance required.
Post #1002237 30th Jul 2023 7:57am
I had a galvanised on advertised on here for free as well a while back
No-one wanted it and I chucked it in the end. Typical.
Post #1002238 30th Jul 2023 8:01am
bodstruck
That sounds like the ideal solution, I shall look into that, thanks.
Diesel_Jim - shame, and I have the same thing myself. Sometimes you can't even give stuff away and they end up taking up too much space.
My current challenge, whichever way I go, is getting the old crossmember off. It is stuck solid. I know I need to spread the chassis legs but I can't get the high lift under there, the bottle jack doesn't work on its side and the only scissor jack I have is from my van and it is too big to get into a useful position.
Post #1002247 30th Jul 2023 9:42am
Page 2 of 2 <12
