![]() | Home > Maintenance & Modifications > P38 Steering box Conversion |
I confess i have never heard of this modification.
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1466 ![]() ![]() ![]() |
The only time I've heard of it done was to gain clearance for an engine conversion, Jaguar V8 or Ford 5.0.
Are you changing your engine? |
Shadowfax Member Since: 25 Jul 2023 Location: West Sussex Posts: 6 ![]() ![]() ![]() |
Possible change to M57 but not concrete yet. All i know is i want to change the old 300tdi (Great engine but do miss my TD5) out to keep up with modern traffic and improve the refinement on longer journeys.
Steering box also needs rebuilding or changing out for a recon box. Hence why the possible change if im changing it out, do i change it for a potentially better box. |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 ![]() ![]() |
The blackbird kit is essentially what was used on the 70th anniversary defenders with the 5L V8’s, Mike who runs blackbird used to work at bowler when they built them. If LR were willing to use that type of set up then I would imagine that the impact on geometry is going to be low
Given that your steering linkages have to run through the wheel arch, depending on your suspension set up clearance can be very tight. |
Thats great to know thank you
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 523 ![]() ![]() ![]() |
What M57 are you fitting. I have done the conversion with the X5 engine and changed the PAS pump and air con pump with a 330d one and was an awful lot cheaper then buying the black bird industries bracket
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 871 ![]() ![]() |
What do you mean by suspension setup? Shocks and springs stay in the same place for 99% of Defender suspension kits (front). |
Refinement I agree about, although I wouldn't expect a huge jump just by switching to another diesel engine. There is far more that makes for poor NVH in a Defender than just the engine. Keeping up with modern traffic should be no problem with a tweaked Tdi, certainly in the UK at any rate. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1230 ![]() ![]() ![]() |
I recall this is also a possible swap for those Land Rover Series users who want Power Steering.
I mean in regards to the shock turrets you use, I run a VB kit which has a shock in front of the turret and I know that it won’t clear the steering column
It is and it worked well on my SIII 88, although I didn't use this kit. |
I guess that would fall into the 1% category then! ![]() BTW, who are VB? |
Its an air suspension crowd, serious piece of kit
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
[quote="Chicken Drumstick"]
Except that the Tdi needs it's neck wringing to keep up, the M57 does it effortlessly 😁 I like mine very much ! I wouldn't change the steering box to a p38 one, if yours needs changing because it's worn out, change it. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
