Home > Off Topic > Dinitrol on lawnmower deck
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
My Mountfield mower of 23 years finally dies - actually the Techumseh engine worked fine. It was the steel deck that totally disintegrated from corrosion.
i've replaced it with a Honda so want to prevent the same from happening again. Has anyone tried Dinitrol on the underside of the steel deck or will this leave a grassy sticky mess once I start mowing?
Post #531451 14th May 2016 9:30am
It will dry, so can't see any issue.
It's a good idea, I intend to do the same myself over this coming winter.
We have a Honda, but a small hole or two appears in the deck so will need rubbing down, repair and filling.
Painting and undersealing.
I'd also consider using stonechip first too.
Nothing can stick any more than wet grass would already anyway so it wouldn't be a concern of mine.
Post #531472 14th May 2016 11:38am
kmac
Cool.
Had pretty much decided to give it a try anyway
Will look at getting some stonechip too.
Its new so thought this would be a good time to protect it
Post #531473 14th May 2016 11:41am
It would indeed, you need to stonechip first though and you'd have only one opportunity.
A little costly but I would personally use
Autotek etch primer, then Autotek stonechip and finally the Dinitrol.
I'd say amounts wise. 1x 2x and 2x. Aerosol would do and total cost probably about £40.
Then you could ACF 50 the winter bits for extra protection too as well. Razz
Please add some photos once done if you proceed. Thumbs Up
Post #531482 14th May 2016 12:02pm
kmac
Job done
Post #537587 4th Jun 2016 10:33pm
Proper job! Thumbs Up Thumbs Up
Post #537597 5th Jun 2016 12:23am
Distorted Vision
I know this is an old thread but I need to do my Mountfield lawnmower. I was just wondering what products you used and in what quantities?
Many thanks!
kmac wrote:
Job done
Post #998231 2nd Jul 2023 4:56am
kmac
As steve suggested above - Sand down completely and then 1 coat etch primer, 2 coats stone chip paint and then 2 coats of Dinitrol. Cannot remember what brands of primer or paint I used.
Post #998326 2nd Jul 2023 9:32pm
Distorted Vision
Great - thanks!
Post #998332 2nd Jul 2023 10:44pm
Distorted Vision
I applied Autotek Stoneguard over Etch Primer which was applied on clean bare metal. There appears to be what looks like crazing in a small area. I was just wondering what has caused this for future reference. It's the first time I've ever used spray paint. I allowed 24 hours for the Etch Primer to cure as per the instructions. Would you advise sanding it down with wet and dry sandpaper? If so, what grit would you recommend?
[/img]
Post #1002055 28th Jul 2023 3:37am
bear100
Funny enough swapped my Honda izzy deck this week! It rusted out in 16 years so pretty good really.
I applied a coating of Gtechnic ceramic and a top coating.
Don’t know how long it will last? But it lasts another 16 years I’m ok with that Very Happy
So easy to clean now though! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1002061 28th Jul 2023 7:26am
Distorted Vision
I'm into detailing and use some Gtechniq products. They make some great products but too expensive to use on my Mountfield lawnmower.
Post #1002064 28th Jul 2023 7:54am
bear100
Yeah it's good stuff i have a fair bit in the collection over the years.
didn't use much tbh, i wanted to give it a clean smooth surface so it would wipe down easier and not hold on to debris, I'm sure the routine of cleaning it will go out the window soon enough Laughing 2016 Range Rover Autobiography 4.4 TDV8
Post #1002067 28th Jul 2023 8:25am
Distorted Vision
Finally finished this little project with the nice weather these past few days.
Start
Stripped to bare metal
Masked up and ready to go
One coat of Autotek Etch Primer
Two coats of Autotek Stoneguard
Two coats of Dinitrol 4941 Corrosion Protection
Masking removed and blade back on
Done.
Post #1003809 11th Aug 2023 7:58pm
Procta
not a bad job that at all, Thumbs Up
A youtuber i sometime watch repairs lawnmowers, from the engine to the decks. Pays peanuts for the lawnmower, spends a few hours and its back up and running again. Thumbs Up
Friend of mine took the mick out of his next door neighbours, He fitted a stiffer spring or something like that to his, to make it sound more aggressive. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1003825 11th Aug 2023 10:39pm
