![]() | Home > Maintenance & Modifications > Saggy rear headlining |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 516 ![]() ![]() ![]() |
I'm just being lazy, what size hole did you drill for the Fir trees,
Looks factory ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10881 ![]() ![]() |
Looking good there Daz, and i thought the same, looks factory fitted
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2051 ![]() ![]() |
![]() Tried 5mm then 6mm to start but was too small for the fir tree clips to go in, so ended up being 6.5mm…..and a good whack with the hammer. Think I saw someone on here went to 7mm. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 786 ![]() ![]() ![]() |
On my 110 DC the factory holes were mostly 6mm.... There was now way the new fir tree's would fit... After experiment ended up with 7.2mm holes. But I suppose it depends on the fir tree's themselves, got mine from YRM
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Looks good 👍 job well done. Wish I could solve my saggyness! |
My fir tree clips came from here:
https://www.ebay.co.uk/itm/Land-Rover-Defe...ect=mobile The self-tapper through the hole in the interior light certainly helped, but it did seem that it needed the extra fir trees to support the weight of the headlining. Also the rear 90 headlining has an unused fixing hole in the centre rib - it seems to be punched through the board but the fabric is not punched through - you can feel for it then use that as a starting point. It’s where the fir tree in my photo that has a flat spot on it behind the interior light. |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 555 ![]() ![]() ![]() |
I've done something similar some time ago, but instead of adding a self-tapping screw, I used a rivnut.
I did not add any additional fixings though, it seems to hold reasonably well so far. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Thanks for the replies lads. Will give it a go
Shane |
