Home > Technical > Problem following attempted theft |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
What age/model do you have? Assume you have the factory alarm system still?
If so, i would advise looking at the wiring diagram for all of the fuses associated with the alarm and confirming they are not blown. Did they remove/tamper with anything else? 02' 110 TD5 Double Cab Rebuild Thread |
26th Jul 2023 2:18pm |
Village Member Since: 26 Jul 2023 Location: Stourbridge Posts: 3 |
It’s a 2011 2.4 Puma with the factory alarm and immobiliser. I’ve checked all fuses and they’re all ok. Nothing else seems to have been tampered with.
26th Jul 2023 3:03pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
On mine they cut the main battery wire which runs under the car from the battery footwell to the driver's footwell. Cheers Don.
26th Jul 2023 3:30pm |
No its not that everything turns on but the it will not crank, banging my head against the wall atm!
26th Jul 2023 3:41pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1654 |
Sometimes if you pull the battery when alarming or tamper with them it’ll lock the 10AS box, unfortunately it can be a new alarm ecu and programming.
26th Jul 2023 4:14pm |
