Home > Puma (Tdci) > Key ignition problems
Vmax
Gibraltar 2008 Defender 110 Puma 2.4 SW Baltic Blue
Has anyone had key ignition problems before.As it doesn't start.
Post #1001714 25th Jul 2023 1:59pm
gcc130
Yes, it’s very common.
My 130 has had two new ignition barrels in 120k miles.
Post #1001715 25th Jul 2023 2:06pm
Vmax
This it is yep
Post #1001731 25th Jul 2023 4:03pm
Vmax
Post #1001733 25th Jul 2023 4:27pm
gcc130
Hi,
You can try changing just the switch, as illustrated, but I’ve had to change the whole key barrel and switch when I’ve done mine.
Getting the two shear bolts out is quite interesting 🤨
Andrew
Post #1001811 26th Jul 2023 9:29am
Vmax
True its happened before. Going to put a button this time. At list if it happens again l don't need to push it.
Post #1001813 26th Jul 2023 10:27am
hornet
That is interesting, please keep us updated which button you use and how you perform the modification, it's on my list as well. It should integrate nicely.
Post #1001997 27th Jul 2023 2:18pm
