Home > Tdi > TDI 200 Lift Pump Area
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Hi all
Does anyone here know about the name of this part (red circle as below pic)?
I had noticed very minor engine oil leaks from that area, can it be replace or can just replace the gasket (not sure the part having gasket or not).
thank you. Smile
Post #1001656 25th Jul 2023 10:27am
geobloke
Do you mean the lift pump gasket? Or is it something else?
https://www.lrworkshop.com/diagrams/land-r...pump_53151
Post #1001671 25th Jul 2023 11:04am
cykoh85
Hi Sir
Nope, I mean something else.
Did you notice before the lift pump go in, there was a part (square shape) attached to the engine block?
Post #1001680 25th Jul 2023 11:46am
geobloke
Ah yes I see now. You are looking for HRC1873. It is bolted into place so just needs to be removed, cleaned and replaced either with a paper gasket of some instant gasket.
Post #1001684 25th Jul 2023 11:52am
cykoh85
Oh, I just google with the part number provided by you, the name is lift pump mounting plate,
thank you so much Very Happy
Post #1001699 25th Jul 2023 12:34pm
geobloke
You are welcome. Good luck Thumbs Up
Post #1001700 25th Jul 2023 12:35pm
