Home > Technical > Electric cooling fan
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
The Defender has a viscous coupled fan driven off the engine.
Why not an electric fan?
The newer JLR product all have electric fans.
Are there any problems with removing the viscous fan and fitting an electric one?
Post #1001509 24th Jul 2023 11:15am
Chicken Drumstick
What vehicle/engine?
Viscous has many benefits still. However in most cases you can fit an electric fan.
Post #1001511 24th Jul 2023 11:30am
steveww
I have a TDCi 2.2 110.
Post #1001512 24th Jul 2023 11:32am
Chicken Drumstick
So the benefits of viscous is it is fully automatic and requires no inputs. They just work..... They are also generally cheap and easy to replace.
An electric fan can save a few horse power as the engine doesn't have to directly drive the fan. Although the higher electrical load required for the fan will off set this some what.
Other advantages of electric fans are you can program them and have multiple modes to kick in at different temps. Or even completely turn it off if wading through deep water. But you will need a sensor a switch, plus fan and wiring.
Not all electric fans are equal, ensure you get one with sufficient flow for you engine and cooling requirements.
The X-Eng X-Fan is quite a nice solution for adding in the sensor: https://foundry4x4.co.uk/index.php?route=p...uct_id=134
Note, different sizes available, so get the right size for the pipes you have.
Personally, I'd probably stick with the factory setup however.
Post #1001515 24th Jul 2023 11:49am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
What Electric fan would you fit if fitting one
Post #1001516 24th Jul 2023 11:56am
steveww
Post #1001538 24th Jul 2023 2:41pm
Mo Murphy
The main benefit of viscous coupled fan over electric is the volume of air that they can move when fully locked. Land Rover fitted viscous fans to the Defender to give maximum cooling when driven hard in hot climates.
Other benefits include no electrical contacts to corrode, no need to cut into your coolant circuit for an inline temperature switch, no need for a new cowl, no need for cable ties through the radiator.
And certainly don't believe the bullshine about reducing load on the engine and freeing up more power, you won't notice any difference 🙂
I'm hard pushed, in truth, to see why you would change to electric !
50 Shades of Pennine Grey
Post #1001574 24th Jul 2023 5:34pm
shanecl
steveww wrote:
Something like this https://www.flatdoguk.com/revotec-electron...-tdci~1960
some money for it Shocked
Post #1001681 25th Jul 2023 11:46am
You can however turn off an electric fan if it is about to be submerged in water, something you cannot di with a viscous fan. Doing so may save both the fan blades and the radiator.
Only a very small percentage of owners will be submerging their fans though.
Post #1001708 25th Jul 2023 1:27pm
Mo Murphy
First spray of water through the rad should cool and unlock the viscous hub if it is locked, which is unlikely.
Post #1001721 25th Jul 2023 2:40pm
Jabberwocky
Luxembourg
Viscous fans are great until they stop working, as mine did on the way back from Albania beginning of this month. I started having overheating issues on long steep hills, checked the fan, still running fine…… on idle. Tricks you into thinking it’s fine, wasn’t until I tried to stop it with a balled up rag that I could see it’s wasnt working under strain. Fortunately I had taken a spare with me so it was a reasonably easy fix.
My issue with electric fans is they are completely at the mercy of a fuse or wiring issues, one break, blown fuse, bad earth and they are done, at least a viscous is driven off the engine, fuses can blow quite easily and you won’t know until that needle pings over to the right.
I’m probably over thinking it but I’ll stick to a viscous and carry a spare when I go on a big journey, but I’m lucky in that I have room to have a spare and carry it correctly so the oil in it doesn’t pool in the wrong way.( they should be stored flat)
Post #1002219 29th Jul 2023 10:03pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
The biggest difference is the power of fan. You cannot compare electric and viscous. With proper workong mechanical fan, it is like starting helicopter. When on full lock and engine on idle, you can feel hot wind on your feet standing behind the car.
And yes, you can stop the fan with bare hand, but better not your hand. Look first on description in workshop manual. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1002233 30th Jul 2023 5:14am
