Home > In Car Electronics > Alpine Reversing Camera |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
Hi, if I read your post correctly your unit gives a blank screen when you select reverse? If that's the case then that's good news as the PO has connected a 12v input from the reversing light circuit to tell the head unit to show the camera screen
In terms of wiring the camera in it will need 12v, earth and an appropriate AV cable to transmit the camera image to the head unit. The simplest way of providing 12v and earth is from the reversing light itself, run a short length of 2 core cable from the 12v and earth at the reversing light to wherever you choose to mount the camera. Unless you choose to take 12v and earth from the radio harness when you run the AV cable from camera to head unit. That's up to you. I mounted my camera above the rear door - rookie mistake, it gets filthy, but then there's not a lot of places on the flat rear surface that don't. I've now developed a habit of wiping my thumb over the lens every time I open the back door. |
24th Jul 2023 10:01am |
