![]() | Home > For Sale & Wanted > [Found] Rubber mat for 90 tub |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
Depends if you want Authentic, I used a D2 mat and cut it to size, much cheaper.
Van Diesel Member Since: 12 Oct 2013 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Good idea. I'd like to look authentic but doesn't need to be authentic.
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 538 ![]() ![]() ![]() |
Go to your local agri merchant and buy a cow mat.
Then just cut it to size. Quality material so also helps with sound deadening.. 04' 90 Td5 CSW.. |
Trebro Member Since: 28 Jan 2016 Location: Hampshire Posts: 241 ![]() ![]() ![]() |
i have some surplus converor belt matting, its about 600mm wide, approx 8mm thic, lay flat and its very heavy duty and great sound proofing
