Home > Faults & Fixes (L663) > Park Brake Fault
Moolie
Australia
Park Brake Fault
Hi All.
On the weekend I took an update to pivi pro. I also disconnected the park brake plug at the back of the park brake switch to install a 2way radio.
Now I am getting a park brake fault. I checked the plug, it's in tight. The lights are also on in the park brake switch. I took the car for a short drive to fix and the park brakes are definitely on. Issue didn't clear.
I have attached he'd some photos of the errors.
Is there anything I can do to clear this issue or is a triple the dealer required.
Thanks
Michael
Post #1001362 23rd Jul 2023 8:24am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Here are your photos
I would guess that the car has detected that the brake switch wasn't attached and has stored a fault in the system. If you don't have a suitable code reader you will have to visit your dealer or an independant garage that has a Pathfinder system to clear the fault. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1001366 23rd Jul 2023 8:59am
mmbanf
Italy
hi, it happened to me too
I solved it by disconnecting the battery negative connector for 5 minutes. worth a try.
Marco
Post #1001369 23rd Jul 2023 9:25am
