![]() | Home > General & Technical (L663) > Engine coolant type |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 ![]() ![]() |
ls this the correct coolant?
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 ![]() ![]() ![]() |
If you don’t get answer on here, email Opie Oils. They should be able to tell you. 2007 110 TDCi Station Wagon XS
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 ![]() ![]() |
In the iGuide (Lubricants and Fluids) it states the coolant should comply with STJLR.651.5003 - Tried that in a search on Opie Oils - several options available. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Checked on Opie oils.
Yes, it's the right type for my D250 Should have trusted my LR specialist! ![]() Click image to enlarge |
UPDATE
lt's the wrong colour! The antifreeze in my Defender is a yellow colour and this is pink. l know it doesn't matter but l want to use the same, so it looks like a trip to the dealer. FURTHER UPDATE The genuine Land Rover antifreeze is pink as well. So l guess that's just the way it is. |
