Home > Maintenance & Modifications > Building a Jaguar V8 powered 90
Page 3 of 3 <123
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Heres an example of one done if its the AJ-V8.
Potentially an "easier"... but certainly a cheaper swap to do if you want a V8.
JE Engineering 4.4 V8:
Link: https://www.autotrader.co.uk/car-details/2...mp;fromsra 4.0 V8 Defender 90
My Instagram
Post #1001062 21st Jul 2023 7:01am
Linds Hanson
steveww wrote:
Modern ECU do more than just control the spark and fuel. That's what makes them tricky to swap over as part of an engine swap. However, there are numerous stand alone ECUs from various manufactures available. I've used Motec in the past. Getting the ECU connected up is easy, the tricky part is developing the map. This takes many hours on a rolling road which soon gets expensive.
If I had the time and the money, I'd like to try the JLR 4.4 diesel V8 in a Defender.
Neither 3.6 or 4.4 TDV8 fit Defender chassis being too wide to fit between the rails.
Post #1001070 21st Jul 2023 9:02am
Page 3 of 3 <123
