Home > Maintenance & Modifications > Automatic shifter options
webbug
United Arab Emirates 2016 Defender 110 Puma 2.2 SW Auto Alpine White
Mr. Green Hi there,
I planning to do the automatic transmission conversion from Ashcroft. Unfortunately the gear shifter that I wanted isn’t available (the one that Kahn design use)
This is the one available, can you help me find a direct replacement either to the whole shifter unit or at least the stick
Post #1001007 20th Jul 2023 3:25pm
ashtrans
Site Sponsor
Hi,
its not that easy, the shifter gates that denote each of the 7 positions must be correct for the 4HP22, you can just use any shifter or the shifter gate won't allow the gearbox selector shaft to be in the correct orientation which will cause a box failure,
Dave Dave
Post #1001019 20th Jul 2023 5:45pm
webbug
Thanks Dave for the prompt reply.
What about the top handle insert ?
Post #1001020 20th Jul 2023 5:57pm
