Home > Puma (Tdci) > Oil leak on the left |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 |
hi Hive mind,
Daisy (09 2.4 63000mi) has a leak. Have cleaned the sump and bottom of engine with brake cleaner, looking underneath it comes from the left (looking at the engine) in the area shown in the pics, can’t see anything higher up but haven’t taken the fan cowl off yet to explore. She does have a weeping gasket on the vacuum pump that is going to be replaced and I can trace that down separately; oh and the sump plug is a bit leaky too! But any thoughts on this one please, she’s a daily driver so would rather be prepared and get all done at once with an oil change if I can. Click image to enlarge Click image to enlarge 2.4TDCI 90 - everyday brilliance S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
20th Jul 2023 9:10am |
Thanka MK that makes sense, so replacement would be this… https://www.defender2.net/forum/topic24247.html 2.4TDCI 90 - everyday brilliance
20th Jul 2023 2:40pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
But before taking that way I would change the vacuum pump gasket and give another clean with brake cleaner or alike and a cloth. Then check it again. Puma 110" SW
20th Jul 2023 2:49pm |
👍👍 2.4TDCI 90 - everyday brilliance
20th Jul 2023 3:38pm |
