Home > Puma (Tdci) > Handbrake wire ?
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Handbrake wire ?
Anyone out there know where cable on handbrake switch goes to have switch on hand brake but no trace of wire or whare it goes or what type of connecter just one of those jobs been meaning to do have never had light on dash since owning the beast for 4 years many thanks chaps Endeavour To Persevere
Post #1000871 19th Jul 2023 6:16pm
Devon-Rover
It's on the lever unit itself.
Pulling back the gaiter should reveal all. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1000874 19th Jul 2023 6:47pm
110 Iain
Have striped back but have no wire at all has been removed at some point have checked underneath but cant find anything Endeavour To Persevere
Post #1000875 19th Jul 2023 6:50pm
rustandoil
Remove the centre seat panel.... You should be looking for a white wire with a grey tracer
Post #1000883 19th Jul 2023 7:54pm
110 Iain
Have pulled all carpets no trace of any wire from switch on hand brake where does wire go to and connect so I can make up new loom think whole wire has been cut out in past Endeavour To Persevere
Post #1000885 19th Jul 2023 7:59pm
rustandoil
You might be able to see from underneath, but it will be way easier to remove the metal panel under the centre seat or cubby box if you have one, the handbrake wire has a small bullet connector before it goes into the loom.
Post #1000889 19th Jul 2023 8:21pm
110 Iain
Anyone know where wire connect into loom can I access from under car so I can feed a new wire in thanks for all replys Endeavour To Persevere
Post #1000931 20th Jul 2023 8:07am
As far as I remember it is bundled into the main harness which runs over the top of the gearbox extension and transfer box.
Post #1000975 20th Jul 2023 12:32pm
110 Iain
Thank you blackwolf found stub of wire over transfer box and
ran new cable to hand brake now to move on to missing reverse wire and plug thanks to all again[/b] Endeavour To Persevere
Post #1001436 23rd Jul 2023 5:42pm
