Home > Puma (Tdci) > Red Booster. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 559 |
that sounds like a good set up which ive given a bit thought to trying, but other jobs have been getting in the way... can you give us a clue what transducer you got and where from.. whilst my set up is working well my system doesn't hold the vacuum for more than a few min after the engine is shut down...not sure where it is loosing it from, im guessing it could be any of the connections which if I remember were all just pushed on and I can't recall using clips..
16th Jul 2023 5:21pm |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
Hi there yes the transducer was bought via ebay. They are still available. Search for Gas Pressure Sensor Transmitter Module Negative Peessure -100 to 0 kPa. I have found an item on ebay that is the same it's eBay Item No. 254670377358 there are several sellers though. They cost about £5.30 with postage. Note these are chips so you need to really make a circuit board to mount them. They produce an analogue output inversely proportional to vacuum between 1 and 4 Volts so you need to power them with a regulated 5 V dc supply. If you are not into electronics you may struggle. I used a small 8 pin microcontroller to monitor the output and do the job of A to D conversion and to drive the Mosfet gate for powering the Vac pump. If you want a simpler arrangement a simple switch and a relay that you operate when you turn on the ignition that powers the vac pump to get you a good vacuum may be suitable for your needs. The vac pump I used (also through ebay) draws 5 to 6 Amps so that's why it's best to drive with a relay or a Power Mosfet not directly by a switch. The pumps are also a very inductive load so you need to use a Diode across your relay contacts or Mosfet to deal with the negative switch off spike to protect your relay contacts or Mosfet.
Your Vac leak parh can be anywhere but I found if you don't used Jubilee or equivalent clips you generally cannot assure a gas tight seal. Silicone tubing is best I found or the butyl rubber tubing supplied with the Red Booster seems good but only with clips. The Non Return valves are also a potential leak path so maybe worth replacing. Good Luck. "You are never to old to learn something new" |
16th Jul 2023 7:33pm |
Sorry Andy66 slight error the vac sensor outputs 0.5 to 4.5 Volts. "You are never to old to learn something new"
17th Jul 2023 5:09am |
thanks for taking the time...and when I was thinking about it I had envisaged just connecting the pump to a mechanical switch that just started the pump when the pressure was high and shut it off when a vacuum built up.. the problem I could envisage was making sure the motor did shut down when the engine pump was working....and thats why I would keep the electronic option open, as im sure it can be adjusted to suit..but a bit more involved as its not something im competent with, but given the right information im sure I could manage... the rapid loss of vacuum is something I could improve on as you say but when all works fine when running I just haven't got round to looking into it.. thanks again @B4Lamb |
17th Jul 2023 6:30am |
Hi Andy63, yes there are mechanical vacuum switches readily available but I've not found one that states its one and off vacuum pressure or the tolerance between switches and the effect of temperature. The electronic solution overcomes all these doubts but maybe the mechanical switch would be perfectly suitable for you. You could easily include an in-line switch to turn it off if it runs on when the engine is running. If you do have a leak path then you will not get the full vacuum pressure which could add to the risk that the mechanical switch may not turn off. Its worth a go though I think. The main reason for the electronic one for my friend was that he noted loss off vacuum when he was in traffic braking and changing gears a lot while towing his caravan. The electronic one turns on his pump before it drops to a noticeable level. This feature also appealed to me but I was also interested in the analogue output of the transducer so I can display the vac pressure on my digital OLED display. "You are never to old to learn something new"
17th Jul 2023 9:13am |
Very Rural Member Since: 04 Jul 2023 Location: Shropshire Posts: 58 |
Thanks for the very detailed information.
I have now made the decision, (rightly or wrongly!) & purchased the LOF Power master cylinder & spring kit. If it does the job, then fine, if it doesn't then at least I've not spent too much & can look at the RB at a later date. Having spent more than intended on a replacement galvanised chassis, plus a Glyn Lewis complete mud flap/ wheel arch kit, I can't currently justify the Red Booster cost. I too have the knee problem, so I shall see how it goes. Any improvement will be a help, as I have to keep the Landy going & in perfect order, - it being the only vehicle that can access my rural location. I will report back when I can. |
18th Jul 2023 11:52am |
OleDave Member Since: 19 Oct 2013 Location: CARDIFF Posts: 175 |
Hi very rural, I have no experience with the LOF system so im unable to comment, will look forward to hearing its a success or not.
Regards Ole Dave |
18th Jul 2023 12:23pm |
Have now fitted the LOF master cylinder/spring combination.
It's definitely made a real difference, obviously not as light as the Red Booster would be but I can now hold the pedal down without my left knee complaining. I shall see how it goes on a long run.. |
21st Aug 2023 7:30am |
Hi very rural thanks for the post, im pleased to hear that the fitting of the LOF spring option has been a success, my problem was not pressing the clutch in, even though that did hurt, my problem was letting it out as my knee would give way which meant no clutch control, it was either in or out, Nasty experience!!!!!
May I ask if you have that problem or is it just depressing the pedal only you had problems? The booster I found gives me total control of depressing and release, in fact I found it made gear changes a lot more controllable and smoother with litte or no clanging of the transmission due to the diff and drive shafting clearances catching up. Many thanks for the contact Regards Ole Dave |
21st Aug 2023 4:04pm |
Thanks for your interesting reply.
My main problem was pressing the clutch pedal down, & in particular holding it there, for instance when creeping slowly on a congested motorway. I shall see how it goes, if I do need to I could upgrade to the R.B., but it is an expensive option. Ideally an auto box.... Even more expensive. I do miss my auto Discovery 1, which I sold a few months ago! David. |
21st Aug 2023 5:01pm |
