Home > Maintenance & Modifications > Optimill quick boss plus 350 steering wheel.
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Just asking if this is a worthwhile mod, alongside the security shroud gizmo that Optimill do.
Quite a lot of money so any more feedback is welcomed. I have a Td5, (48 spline if any one has one to shift?!)
Many thanks
Rob
Post #998619 4th Jul 2023 6:37pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I have the optimil steering boss with a momo tuner. Glad I did it as it gives the impression of more elbow room etc. I haven't got the security cover though. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #998621 4th Jul 2023 6:43pm
90 Dreamer
Proabbaly one of the best visible detergents there is with the lock boss.....
Post #998625 4th Jul 2023 6:55pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
ditto - one of the best deterrents and can be utilized anywhere
Post #998634 4th Jul 2023 7:18pm
DC101
Thanks for replies.
Security cover for boss seems to be getting very favourable reviews. Would mean I can ditch the disclock..!
Post #998649 4th Jul 2023 8:54pm
Dick
United Kingdom 1994 Defender 90 200 Tdi HT Shire Blue
First thing I ordered for mine the day I went to pick it up.
And how glad I was as someone screwdrivered the drivers door the first week I owned it.
Probably opportunist looking for tools / contents more than anything but I can sleep easy knowing that even if I left the thing completely unlocked, it ain’t going anywhere.
That combined with a ‘ardcase is, I’m hoping, going to suitably foil most.
Post #998849 6th Jul 2023 10:04am
Jabberwocky
Luxembourg
For me the optimill stuff is very hit and miss, the doors handles for instance are appalling for the money, but the steering wheel boss and lock thingy is an absolute must although the lock thing is an arse to put on, trying to line up the holes is a thing of nightmares.
Post #998986 6th Jul 2023 11:18pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
When you put the swivel lock on, put your finger on the "top" hole. Look for the "top" lug on the steering wheel boss and when putting it on feel for top lug on your finger nail. Works for me 95% of the time and it really isn't a pain to fit anymore. Saves a lot of cursing as just trying to lign it up is tricky as you put it on but the centre section is free to move so unless you have it spot on it turns - with your finger on the hole it stops it spinning.
Post #998995 7th Jul 2023 5:46am
Dick
Ha - this is a good little trick - did have me cursing the first time I tried to fit it!
Post #999000 7th Jul 2023 6:42am
Tegner
with the locking lug at 3 o'clock( swivel lock) put a small piece of tape at 12 o'clock it should line up with the top hole, you then line up the tape with the top lug on the steering boss, works for me
Post #999002 7th Jul 2023 6:44am
90 Dreamer
Just put a small mark on the inner and its a piece of pi%%
Post #999105 7th Jul 2023 6:53pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I just look where the "Top" pin is on the boss, (top centre of course if wheels were straight ahead) and then quick glance inside the swivel to find the equivalent hole and then just marry them together. Goes on first time 99% of the time, other 1% just needs a slight wiggle.
Takes 10 times longer to explain in writing than to actually do.
Post #999914 13th Jul 2023 1:15pm
I'm afraid I simply don't understand how anyone can have the slightest difficulty fitting the Optimill lock, it could hardly be simpler.
Post #999960 13th Jul 2023 5:51pm
judders
England 2015 Defender 110 Puma 2.2 XS CSW Indus Silver
I've just fitted the Optimill QR boss and I also have the security cover. Also, no issues at all for me fitting the security cover. Very neat solution.
Question for those that have it - when you park away from home, what do you do with the steering wheel? Do you secure it somewhere in the truck?
Post #1000082 14th Jul 2023 11:02am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
It depends. If I'm staying in a hotel, then I take the wheel in with me. If I'm going on a hike, I hide the wheel out of sight.
For extra security you could securely attach the wheel to something inside the Defender with a bicycle type lock. Belt and braces.
Post #1000086 14th Jul 2023 11:06am
