Home > Tdi > Battery for 200 tdi |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1542 |
its not the correct battery for the truck and doesn't look to be fixed in place either
you have a couple of options go back to the correct one, fit a twin battery set up , or maybe modify the battery box itself as some of the aftermarket ones are flat floor and allow for some different positioning of batteries and extras. |
2nd May 2024 8:28am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
As Darren eludes to move it through 90 deg and reposition some of the other stuff. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd May 2024 10:05am |
I believe the factory original battery was a 072 which has dimensions of 266L x 175W x 220H.
It was very very common that these were "upgraded" to a 110 battery which has dimensions of 317L x 175W x 175H. The reason was the bigger capacity and sometimes better CCA. It looks like yours might be bigger than a 110, unless it is sitting on something. Your battery is 329L x 171W x 240H so the additional height and length is your problem. |
2nd May 2024 2:38pm |
RevRon Member Since: 31 Mar 2024 Location: Scotland Posts: 2 |
Thank you all for your advice.
I will order a new battery for now, long term I think I will go down the duel battery route. |
4th May 2024 9:40am |
