Home > Tdi > Battery for 200 tdi
RevRon
United Kingdom 1994 Defender 90 200 Tdi HT Coniston Green
Battery for 200 tdi
What is the correct battery for the 200 TDI
My defender had a new battery fitted during its renovation problem is that the negative terminal is hitting the battery box cover.
Post #1033553 1st May 2024 10:09pm
Mdm
its not the correct battery for the truck and doesn't look to be fixed in place either
you have a couple of options go back to the correct one, fit a twin battery set up , or maybe modify the battery box itself as some of the aftermarket ones are flat floor and allow for some different positioning of batteries and extras.
Post #1033574 2nd May 2024 8:28am
jst
As Darren eludes to move it through 90 deg and reposition some of the other stuff. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #1033587 2nd May 2024 10:05am
geobloke
I believe the factory original battery was a 072 which has dimensions of 266L x 175W x 220H.
It was very very common that these were "upgraded" to a 110 battery which has dimensions of 317L x 175W x 175H. The reason was the bigger capacity and sometimes better CCA. It looks like yours might be bigger than a 110, unless it is sitting on something.
Your battery is 329L x 171W x 240H so the additional height and length is your problem.
Post #1033618 2nd May 2024 2:38pm
RevRon
Thank you all for your advice.
I will order a new battery for now, long term I think I will go down the duel battery route.
Post #1033784 4th May 2024 9:40am
