Home > Td5 > Manual swap to automatic
Patrik2102
Croatia 1999 Defender 110 Td5 SW Alpine White
Hello, I bought 110 99' td5 with broken engine. I'm looking for new engine and thinking to put autobox, is that possible and what else I need beside autobox
Thank you
Post #1031322 12th Apr 2024 7:57am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Ashcroft transmission do a conversion kit using the ZF auto box from a Td5 discovery not cheap but it can be done 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1031336 12th Apr 2024 10:32am
The Gribbin
United Kingdom 2001 Defender 90 Td5 HT Auto Caledonian Blue
Re: Manual swap to automatic
Thank you
The best thing I have done to my Landy, so much more relaxed driving... supposed to be better off road, but I haven't tried that yet.
I have a Stage 2 tune, that helps, with cruise control, happily sits at 70 mph on the motorway.
Bit far for you, but Ashcroft did my conversion, looks factory... I'm sure you could get someone local to fit heir kit... recommend the larger torque converter.
Enjoy!
Post #1031453 13th Apr 2024 8:41pm
NickMc
As above Ashcroft’s do a complete kit and ships worldwide
https://ashcroft-transmissions.co.uk/produ...-auto-kit/
Post #1031470 13th Apr 2024 11:50pm
MarkBrown
United Kingdom 1983 Defender 110 Other HT Auto Keswick Green
My opinion is that it is without doubt the best modification to a defender which will transform the vehicle both on and off road, especially with some engine power upgrades at the same time.
Post #1031480 14th Apr 2024 8:21am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Time to fit an M57 and 6 speed auto then 😁 you won't look back.
Post #1031529 14th Apr 2024 4:25pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I second that. M57 with an auto box is the way forward. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #1032883 26th Apr 2024 7:18am
Linds Hanson
Mo
Even better with a 8HP 8 speed
Post #1032921 26th Apr 2024 10:32am
