Home > Td5 > Manual swap to automatic |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 107 |
Ashcroft transmission do a conversion kit using the ZF auto box from a Td5 discovery not cheap but it can be done 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
12th Apr 2024 10:32am |
The Gribbin Member Since: 25 Mar 2022 Location: Tewkesbury Posts: 29 |
The best thing I have done to my Landy, so much more relaxed driving... supposed to be better off road, but I haven't tried that yet. I have a Stage 2 tune, that helps, with cruise control, happily sits at 70 mph on the motorway. Bit far for you, but Ashcroft did my conversion, looks factory... I'm sure you could get someone local to fit heir kit... recommend the larger torque converter. Enjoy! |
13th Apr 2024 8:41pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
As above Ashcroft’s do a complete kit and ships worldwide
https://ashcroft-transmissions.co.uk/produ...-auto-kit/ |
13th Apr 2024 11:50pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 332 |
My opinion is that it is without doubt the best modification to a defender which will transform the vehicle both on and off road, especially with some engine power upgrades at the same time.
14th Apr 2024 8:21am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
Time to fit an M57 and 6 speed auto then 😁 you won't look back.
Mo The Land Rover 90 - Many are called, few are chosen. |
14th Apr 2024 4:25pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
I second that. M57 with an auto box is the way forward. 2008 Defender 110 XS SW - M57N2 / 6HP28X
26th Apr 2024 7:18am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 445 |
Even better with a 8HP 8 speed |
26th Apr 2024 10:32am |
