Home > In Car Electronics > Wiring loom into door
Screbble
I’m being a bit lazy as I really should have a closer look in daylight…
I need to remove the passenger door to replace it soon so I am ‘hoping’ there is plug either in the door or in the A pillar?
I have electric windows and central locking.
I can cut and reconnect easily enough but prefer not to Very Happy
Anyone got an answer and maybe even a photo?
Thanks in advance Thumbs Up
Post #1026834 4th Mar 2024 7:51pm
Wag
Northern Ireland 2006 Defender 90 Td5 HT Tonga Green
Thumbs Up Easy job on a td5 should be 2xplugs in the door pillar I had to replace this loom as the internal cables had nipped.
Post #1026840 4th Mar 2024 8:09pm
Screbble
Thanks Wag that was the answer I was hoping for.
Do you know if I can pull the plugs through the grommet hole to disconnect or do I have to access from inside the footwell?
Post #1026842 4th Mar 2024 8:24pm
Wag
You'll be able to gently work them free through the grommet hole. The plugs are to big to fit up the rubber flexi,so it will be a cutting and soldering game behind the door card if anything is brittle and nips but you are replacing the door so it shouldn't matter .
Post #1026846 4th Mar 2024 8:45pm
Screbble
Thanks very much - super helpful 👍
Post #1026850 4th Mar 2024 8:53pm
Connectors are just into the bulkhead below the A pillar if I remember rightly, or you can disconnect in the door there shouldn’t be any need to cut anything just work the rubber out of its seats on each side if you need to move it. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1026852 4th Mar 2024 8:57pm
Screbble
Thanks Steve Thumbs Up
Post #1026880 4th Mar 2024 10:57pm
