Home > In Car Electronics > Wiring loom into door |
Wag Member Since: 27 Nov 2023 Location: Londonderry Posts: 8 |
Easy job on a td5 should be 2xplugs in the door pillar I had to replace this loom as the internal cables had nipped.
4th Mar 2024 8:09pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2063 |
Thanks Wag that was the answer I was hoping for.
Do you know if I can pull the plugs through the grommet hole to disconnect or do I have to access from inside the footwell? |
4th Mar 2024 8:24pm |
You'll be able to gently work them free through the grommet hole. The plugs are to big to fit up the rubber flexi,so it will be a cutting and soldering game behind the door card if anything is brittle and nips but you are replacing the door so it shouldn't matter .
4th Mar 2024 8:45pm |
Thanks very much - super helpful 👍
4th Mar 2024 8:53pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
Connectors are just into the bulkhead below the A pillar if I remember rightly, or you can disconnect in the door there shouldn’t be any need to cut anything just work the rubber out of its seats on each side if you need to move it. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
4th Mar 2024 8:57pm |
Thanks Steve
4th Mar 2024 10:57pm |
