Home > eBay & Bargain Spots > Links to correct engine oils on AMAZON |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6492 |
Your links are to Total so can’t convert them! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Nov 2019 11:26pm |
Amazon don’t have everything, I had a reasonable trawl through to turn up the ones above. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Nov 2019 11:50pm |
Andy T Member Since: 25 Aug 2017 Location: Bucks Posts: 218 |
This is SO useful, thank you. Can't wait for the TD5 and Diff/transfer case/gearbox info all in one place too
14th Nov 2019 12:45am |
doncarloz Member Since: 29 Oct 2017 Location: Styria Posts: 60 |
What engine oil spec should be used for a NON-DPF 2.2 TDCI? Just asking for a friend
18th Feb 2020 10:03am |
DieselDriver Member Since: 13 Dec 2017 Location: Carinthia Posts: 244 |
Hi,
where do I find the oil list for Td5? Thanks. |
10th Mar 2020 10:39pm |
APK Member Since: 13 Jan 2015 Location: London Posts: 255 |
Hi Martin, Many thanks for this list. Do you have one for the 300Tdi? Also, has the link for Diff/transfer case and gearbox oils been posted? Kind Regards APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
22nd Aug 2022 2:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19665 |
I used Castrol Edge Professional C1 5w-30 fully synthetic in my 2.4.
Meets ACEA C1 Jaguar Land Rover engine oil specification STJLR.03.5005. Suitable for use in 2.4 and 2.2 with DPF, it’s what JLR use. The good thing is, that it’s backward compatible with the 2.4, and fully up to spec to use on a 2.2 with DPF. Eric on here, had his 2.4 into JLR and they used the above as it’s higher spec for an 2.4 and now used for both the 2.4, and 2.2 with or without DPF. It’s one of the higher spec oils, and isn’t particularly cheap. It runs really nicely, I did my service a week or two ago with genuine service parts. You may be able to find it on Amazon? If not, Opie Oils with discount code ‘DEF2’ for forum members, there is no doubt other site sponsors that I would imagine stock it too. I used to use Fuchs also good, I thought I’d go over to Castrol, as Ford commonly use it and is a typical associate with Ford TDCi motors. I shall be moving over to Castrol professional, diff oil, transfer box, MT82 (GL4 spec).etc in due course. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Mar 2024 7:58pm |
