Home > eBay & Bargain Spots > Links to correct engine oils on AMAZON
Page 2 of 2 <12
Martin
Site Admin
Your links are to Total so can’t convert them! Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #800544 2nd Nov 2019 11:26pm
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
You’ll find the products on Amazon I expect. I posted them back to our website specifically to keep them clean of any specific supplier. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #800546 2nd Nov 2019 11:40pm
Martin
Site Admin
Amazon don’t have everything, I had a reasonable trawl through to turn up the ones above.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #800547 2nd Nov 2019 11:50pm
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
This is SO useful, thank you. Can't wait for the TD5 and Diff/transfer case/gearbox info all in one place too Very Happy
Post #802180 14th Nov 2019 12:45am
doncarloz
Austria 2015 Defender 110 Puma 2.2 DCPU Stornoway Grey
What engine oil spec should be used for a NON-DPF 2.2 TDCI? Just asking for a friend Very Happy
Post #815752 18th Feb 2020 10:03am
DieselDriver
Austria 2003 Defender 110 Td5 SW Belize Green
Hi,
where do I find the oil list for Td5?
Thanks.
Post #819077 10th Mar 2020 10:39pm
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Martin wrote:
Hi all,
Here is a list of links to Amazon of the correct engine oils for the Defender 2.2 Puma with DPF.
Hi Martin,
Many thanks for this list.
Do you have one for the 300Tdi?
Also, has the link for Diff/transfer case and gearbox oils been posted?
Kind Regards APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #962520 22nd Aug 2022 2:56pm
I used Castrol Edge Professional C1 5w-30 fully synthetic in my 2.4.
Meets ACEA C1
Jaguar Land Rover engine oil specification STJLR.03.5005.
Suitable for use in 2.4 and 2.2 with DPF, it’s what JLR use.
The good thing is, that it’s backward compatible with the 2.4, and fully up to spec to use on a 2.2 with DPF.
Eric on here, had his 2.4 into JLR and they used the above as it’s higher spec for an 2.4 and now used for both the 2.4, and 2.2 with or without DPF.
It’s one of the higher spec oils, and isn’t particularly cheap.
It runs really nicely, I did my service a week or two ago with genuine service parts.
You may be able to find it on Amazon?
If not, Opie Oils with discount code ‘DEF2’ for forum members, there is no doubt other site sponsors that I would imagine stock it too.
I used to use Fuchs also good, I thought I’d go over to Castrol, as Ford commonly use it and is a typical associate with Ford TDCi motors.
I shall be moving over to Castrol professional, diff oil, transfer box, MT82 (GL4 spec).etc in due course.
Very Happy Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1028188 15th Mar 2024 7:58pm
Page 2 of 2 <12
