Home > 130 > 130 rock and tree slider dimensions |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 342 |
I have a set of rock/tree sliders on mine that i am happy to get some dims for you. can i ask what sizes you are specifically after? _ I am not near my motor today so will have to be tomorrow when i get the sizes for you. Defender 130 HCPU TD5
30th May 2023 8:50am |
Ratty43 Member Since: 01 Sep 2021 Location: Cornwall Posts: 87 |
Thanks for the offer! I've been meaning to update this as in the end I realised that if push came to shove I would have to modify a set. I've gone for the Safariequip ones which, by a minor miracle just fit inside the sills of the Quadtech. Thanks to land rover tolerances they are very tight on the passenger side so don't quite run parallel to the body. It did take a bit of cutting at the front of the box.
Click image to enlarge |
30th May 2023 10:49am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3332 |
Speak to Shire Fabrications : https://www.shirefabrications.com/
30th May 2023 11:32am |
