Home > V8 > Factory 3.5 V8 FEAD Setup |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 490 |
Thanks! Don't worry about the links, I think I'm going to chuck it all together using the parts/bracketry I got from the RRC setup for now, I can't see anywhere it may foul or cause issues Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
6th Jun 2022 9:35am |
An update on this thread - the engine's all in situ now using the RRC setup for the PAS pump and alternator and hasn't shown up any issues now the wings are in
Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
23rd Jul 2022 10:06pm |
Thanks. I hadn't really considered that - was just after a low profile intake solution to make sure I had enough clearance when the bonnet goes on.
I've seen these filters used on a range of Rover V8 applications, would've thought the Defender engine bay is roomy/draughty enough for it not to be a problem but I want to do an LPG conversion at some point too which will change the setup anyway Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
24th Jul 2022 9:09pm |
